How does localisation work ?
i change the xml to test or create a new one but no modification is taken
Edit : Ok :p it works but can't use accent in the file
Title: Error
Message: Il existe un caractère non valide dans le codage donné. Ligne 6, position 23.
StackTrace: à System.Xml.XmlTextReaderImpl.Throw(Exception e)
à System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
à System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res)
à System.Xml.XmlTextReaderImpl.InvalidCharRecovery(Int32& bytesCount, Int32& charsCount)
à System.Xml.XmlTextReaderImpl.GetChars(Int32 maxCharsCount)
à System.Xml.XmlTextReaderImpl.ReadData()
à System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
à System.Xml.XmlTextReaderImpl.FinishPartialValue()
à System.Xml.XmlTextReaderImpl.get_Value()
à System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r)
à System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r, LoadOptions o)
à System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
à System.Xml.Linq.XDocument.Load(String uri, LoadOptions options)
à System.Xml.Linq.XDocument.Load(String uri)
à Ember_Media_Manager.Localization.LoadLanguage(String Language)
Date/Time: 17/07/2009 21:27:07
Edit Bis : Ok i'm stupid
the xml must be utf-8 encoded and the english one is encoded standard since no special chars
Switching my editor solve the problem.
Will upload a french translation when i have time to finish it
(Or i trade for a $O in the bulk renamer :p i have try to do it but very long time since vb it works but the bulk renamer grid got the columns bug don't understand why )
