Here is a description how i did: go to the movie files (not library) and load movie information. When it's done go to library mode, choose the move and reload movie information. That's it. Try and let me know.
I receive the following error when trying to install from the embersetup.exe on the project page.
--- Main: Installing Files (4/3/2010 11:55:58 PM)
*** Main: WARNING File Hash Not Correct : C:\Program Files\Ember Media Manager\Images\OfflineDefault.jpg
*** Main: END 4/3/2010 11:56:19 PM
I tried it on avi file but i wasn't successfull. Here are my steps:
1. I deleted database
2. nfo and images files
than I add source and load movie informations. Poster and fanart were loaded but nfo file didn't. I think that poster and fanart image is cacheing somewere because its loading after each selecting folder. Movie wasn't added to library.
Don't tick scan recursively at Step 4 and I can't see where you actually Updated the Library.
khaoohs Wrote:I receive the following error when trying to install from the embersetup.exe on the project page.
How long ago did you download it? If it was more than ~10 hours ago, you'll need to re-download. We changed the hashing method in the setup routine. For those of you who already have Ember installed, do not fret, Ember will automatically download the newest version of EmberSetup before upgrading.
the format Lost - 410.mkv is now working but not:
Greys Anatomy 410-411.mkv for multiple episodes...
Beatzeps08 Wrote:Hi,
IS this supported by xbmc?
According to their wiki here, it's not. So is this recognized in xbmc?
http://wiki.xbmc.org/index.php?title=TV_...Library%29
I have a problem with scraping Futurama in DVD order:
At the scraping, after the images selection, i choose "DVD" as the episode order, but ember recognises 5 seasons - which is the standard order. In DVD order there are just 4 seasons:
http://thetvdb.com/index.php?tab=seasona...&order=dvd
The episodes are named as e.g. "S01E01 - Space Pilot 3000.avi", each season files are in their own folder, e.g. "Season 1", within the tv show folder "Futurama".
I haven't posted a bug report yet, just wanted to know, if someone else has the same problem or if its just me. Maybe i'm doing something wrong...
olympia Wrote:IS this supported by xbmc?
No it is not I think, but I thought it was supported by EMM. Maybe I just change my format, thank you anyway
Happy to see TV support, works very well.
But is it possible to add an option, when scraping for TVshow posters you can select the fanart as well.
Roborob Wrote:Happy to see TV support, works very well.
You should be able to choose fanart in the same "TV Image Selection" dialog as for the posters.
So, I just started Ember now and it wants to update to version .....22.
Do I still need the hotfix posted here earlier, after updating, or is it included in the latest auto update?
I blindly bulk renamed during the trailer issue version.
Now I still have dupes and they are named the same as the movie but smaller files.
Any suggestions to fix this should i Just delete them all and rescrape?
Ayla Wrote:So, I just started Ember now and it wants to update to version .....22.
Hotfix not needed after .22 update
