olympia Wrote:In theory it should work, but we don't really know what XBMC exports. Is it both exporting seasonXX.tbn to the show dir and a folder.jpg to the season dir for season poster?
ok, just removed everything (emm) and reinstalled it. all the season thumb are now being detected. but the fanart for seasons are still getting season one copied over for the rest, but again once you tell emm what local file to use it sticks untill you remove it from database.
andyblac Wrote:ok, just removed everything (emm) and reinstalled it. all the season thumb are now being detected. but the fanart for seasons are still getting season one copied over for the rest, but again once you tell emm what local file to use it sticks untill you remove it from database.
I may be misunderstanding what your saying but do you have those file types checked under TV > File and Sources, I don't think ember sees them otherwise
>>X<<' Wrote:I may be misunderstanding what your saying but do you have those file types checked under TV > File and Sources, I don't think ember sees them otherwise
yup, those are checked, and i have local fanart inside season folders, but emm is not seeing them until i manually tell it there are there.
also still got a problem with double episodes, emm is now seeing them fine scrapes then as two episodes, but when i reload the season in XBMC it is seeing both episodes as one, IE
flashforward E11 & E12 is a double episode, emm sees it as such, but now if i reload it in XBMC they are both seen as E11 both got the same titles and thumbs, now if i remove the .nfo & tbn for E11E12 file and reload xbmc finds them as 2 again.
anyone else got this problem ?
andy
Can anyone tell me the advantages of using EMM versus just using XBMC's scraper abilities? XBMC seems to do a fine job at getting posters and info.
andyblac Wrote:also still got a problem with double episodes, emm is now seeing them fine scrapes then as two episodes, but when i reload the season in XBMC it is seeing both episodes as one, IE
andy
Yeah your right its writing the nfo like two normal nfo's in one instead of using the xbmcmultiepisode tag
I just edited my nfo and it now works correctly
Ember writes
http://pastebin.com/5EkYhfEK
Edited with xbmcmultiepisode (try this one it should work)
http://pastebin.com/rYpwZq0j
No takers on the issue I am having?
Hey people!
I just want to know How to order thze tvshows folder...
I have a folder called Series, inside the folder of the series, but if the serie have more than 3 seasons, I have to make a folder for each season?
please help...
>>X<<' Wrote:Yeah your right its writing the nfo like two normal nfo's in one instead of using the xbmcmultiepisode tag
Ember writes
We already have a fix for that on SVN. Not exactly this, but it's working. I thought it has been already released, but it seems not yet. Stay tuned and thanks for the constructive report! Cheers!
Death-Axe Wrote:Having some real issues with Defenders of the Earth. It is here on tvdb http://thetvdb.com/?tab=season&seriesid=...1151&lid=7
Structure as the rest of my things are:
Defenders Of The Earth
Season 1
Defenders Of The Earth S01E01 Escape From Mongo
Defenders Of The Earth S01E02 The Creation Of Monitor
etc.
Posters/banners etc scrape, the season folder show up as Defenders Of The Earth S01E01 in ember, but it refuses to scrape the episodes. rescrape after rescrape, deleted all files rescraped again, same thing. What is going on here?
Death-Axe Wrote:No takers on the issue I am having?
Your structure works for me. Try reseting regex.
Okay, I seem to be having some issues...
I'm running EMM (latest version) in a VMware image on my Mac... it used to work fine, but lately I can't save any files. I'm using a folder on my Mac as the source, it's shared in VMware (so it's really /Volumes/StorageUnit/Downloads/Movies, but is shared with the VMware image as Z:/movies)
Other programs can save files to these directories, but EMM gives me the errors in this pastebin:
http://embermm.pastebin.com/ZQVryW9i
EDIT: That happens if I scrape all movies missing data... I tried just scraping one, and got some similar error messages, but it actually seemed to work! The plot thickens...
http://embermm.pastebin.com/JpD9ya55 has the two error messages it gave at the end (the ones around 2:20 PM instead of 2:16 PM)...
Please help on my issue! I already posted a few pages back...
When I update the library and scrape all new movies, nothing gets scraped. The only way I can scrape a movie is if I do it one at a time, which is a pain. I miss the ability to scrape all new movies, and have the scraper do it automatically. Does anyone else have issues scraping their movies in bulk? Happy to report TV Shows work great
clock2113 Wrote:Okay, I seem to be having some issues...
Delete DB (Media.emm) add sources and try again.. this is old issue that happen when upgrades over a old DB (<1.0)
UnisonRuss Wrote:Please help on my issue! I already posted a few pages back...
Please do a clean install.. set sources correctly (special note about the one movie per folder setting).
Also check if any error popup (red flag upper right corner)
sphere Wrote:Yes, ember can fetch season Posters (and even Season Fanart).
I think SHen350 meant that, yes: when you rename the files to "S01E01" etc. ember can scan them. And after ember has scanned them, ember can scrape them
regards
sphere
Thats pretty much what I meant. I also went back and added the pt 1 and so on to them to see what would happen, EMM scanned them in correctly. So, maybe it's not a problem with your naming, but the way they are in the file? I don't really know what else might be cuasing the problem.
