Moldiver Wrote:When scraping movies my EMM only seems to scrape thumbs or really small pics, sometimes i will get a 720p or 1080p but always seems to be small pics. Anyone got any ideas?
Have you gone into settings and specified the size of pics you want scraped?
Anyone pls can help me with tv-shows iso's ?
I have
FLINTSTONES_S01E01E02E03E04E05E06E07.iso but EMM see only 01,03,05,07
from
FLINTSTONES_S01E08E09E10E11E12E13E14.iso EMM see only 08,10,12,14
from
FLINTSTONES_S01E15E16E17E18E19E20E21.iso EMM see only 15,17,19,21
from
FLINTSTONES_S01E22E23E24E25E26E27E28.iso EMM see only 22,24,26,28
so its only each 2nd episode.
How the correct naming is for such iso ?
Edit:
FLINTSTONES_S01E01.S01E02.S01E03.S01E04.S01E05.S01E06.S01E07.iso works but is there a shorter way ?
Is there a way to keep genre and mpaa rating but not show the icons? I can set genre to none and the icons are gone, setting mpaa rating to none does nothing.
bobrap Wrote:Is there a way to keep genre and mpaa rating but not show the icons? I can set genre to none and the icons are gone, setting mpaa rating to none does nothing.
delete the icons from the respective folders.
Gee, ya think it could be any simpler? :o
I thought it was easy...are there more than one location for the icons? I removed them from C:\Program Files\Ember Media Manager\Images\Genres, but there still appearing? Sorry for the trouble.
Is anyone by chance hosting a pre-compiled SVN build somewhere? 1.1 is locking up on me way too much and I keep reading that 1.2 is soon but I got a ton of media I need to parse through and really dont want to install a bunch of software that I will never use again on my PC.
If someone has a link or is hosting a recent SVN build for 1.2 please let me know!
TYVM
pfriederichs Wrote:Is anyone by chance hosting a pre-compiled SVN build somewhere? 1.1 is locking up on me way too much and I keep reading that 1.2 is soon but I got a ton of media I need to parse through and really dont want to install a bunch of software that I will never use again on my PC.
TYVM
We have never heard about what locks you up in 1.1. Could you please elaborate this general statement?
I will see if I can post any kind of log tonight after work but it would randomly lock up on me once I enabled Trailer Scraping - it would parse mabey 5-10 folders and then appear to just lock.
olympia Wrote:delete the icons from the respective folders.
Where exactly are these folders? I deleted all the genre icons in EMM but they still appear. Thanks
olympia Wrote:We have never heard about what locks you up in 1.1. Could you please elaborate this general statement?
This is an example of the error I get when it hard locks.
Title: Error
Message: An entry with the same key already exists.
StackTrace: at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at System.Collections.Generic.SortedList`2.Add(TKey key, TValue value)
at EmberScraperModule.YouTube.Scraper.ParseYTFormats(String url, Boolean doProgress)
Date/Time: 4/22/2010 1:10:26 AM
I've been using EMM version 1103 and everything's good until I check again today and I install the 1.1 version. it runs very fast and very smooth in searching for new movies but I have a problem that after scanning, none of the poster, fanart, NFO, etc have been saved. But when I switched back to version 1103, everything gets saved. So i'm wondering what might causes that problem.
I'm running EMM on windows 64 bit
Thank you
arryo Wrote:I've been using EMM version 1103 and everything's good until I check again today and I install the 1.1 version. it runs very fast and very smooth in searching for new movies but I have a problem that after scanning, none of the poster, fanart, NFO, etc have been saved. But when I switched back to version 1103, everything gets saved. So i'm wondering what might causes that problem.
Thank you
Have you updated (or using the setings.xml or media.emm) r1103 with 1.1?
You have to do a clean install.
If the answer is no to the above question, then:
http://embermm.com/projects/embermm/wiki...ction-work
