2009-05-07, 22:58
Disclaimer: These are notes are intended for me and me alone. These notes may not work for you or may burn your house down.
Requirements;
Ubuntu 9.04 Server PC; inel 2 core, 4 hardrives 1 terabytes each, 2 gigs ram.
Ubuntu 9.04 Client PC; intel 2 core, 780i nvidia mother board, 9800 GTX, 4 gigs ram.
Gigabit ethernet switch network for 1080p movies.
1a: Install Ubuntu 9.04 with; samba, iscsi-target, nomachine's nx server.
1b: Format the 4 hardrives to ext4 file system.
1c: Samba map the 3 harddrives.
1d: Setup iscsi-target 1 harddrive for 1080p movies over 7 gigs.
1e: Disable gui startup.
NOTES for server:
1a: A gigabyte network with iscsi-target for 1080p movies is a must with more than 3 clients.
2b: Hdparm sleep does not work with iscsi-target or samba.
2a: Install Ubuntu 9.04 client.
2b: Install latest Nvidia drivers.
2c: Install Lirc; Microsoft USB2 -> Direct TV.
2d: Install pulseaudio and libpulse-dev.
2e: Follow this guide for cifs auto mounts on startup.
http://rockpenguin.wordpress.com/2008/05...mountcifs/
# example of /etc/fstab for 1 mount.
//192.168.1.10/storage1 /media/storage cifs credentials=/root/.smbcreds,rw,iocharset=utf8,setuids,file_mode=0666,dir_mode=0777 0 0
2f: Install open-iscisi, auto mount drive on startup, mount read only.
2g: Compile XBMC, do not use "-j2" option.
http://wiki.xbmc.org/?title=HOW-TO_compi...ource_code
NOTES for client:
1a: XBMC crashes when there is high cpu usage.
NOTES for converting DVD library to XBMC VDPAU aware files with near losses quality.
1a: Install HandBrake
1b: HandBrake DVD Lossess quality settings;
Presets -> Basic -> Normal,
MP4 Filetype,
Detelecine,
Deinterlace -> Fast,
Video Quality 65.5 with constant rate factor.
Requirements;
NOTES for server:
NOTES for client:
MP4 Filetype,
Detelecine,
