Hey all,
I'm having difficulty getting a connection. In the system info it shows under network that a link is connected and I can see all the ip addresses there, but when I go to the network settings all it has is eth1 and eth2 and all the ip's are 0.0.0.0 and are greyed out so I can't edit.
I have tried going into /etc/network/interfaces to change eth0 to eth1 but I'm really novice and unsure how to save the settings once I've changed them....
I mean how do you exit once you are in /etc/network/interfaces? it says ^Y to exit but fcuk knows how to exit?? When you exit does it save the the edited script/config?
Can anyone shed any light on this matter?
Cheers
xpertz Wrote:Hey all,
Cheers
You could Google how to use nano to edit text documents in the command line. You'll want to connect, do a "sudo nano /etc/..." and then I believe you hit control-x to exit and "Y" to save. Recalling this from memory so cannot say for sure, but I think that's close enough to get you there...
Check out the wiki for some help [
http://wiki.xbmc.org/?title=Configuring_XBMC_Live], but be careful as some of it is out of date.
jkrellner Wrote:You could Google how to use nano to edit text documents in the command line. You'll want to connect, do a "sudo nano /etc/..." and then I believe you hit control-x to exit and "Y" to save. Recalling this from memory so cannot say for sure, but I think that's close enough to get you there...
Check out the wiki for some help [http://wiki.xbmc.org/?title=Configuring_XBMC_Live], but be careful as some of it is out of date.
Awesome thanks for your help mate. It worked a treat.
Still having problems though, all the ip adresses have populated automatically and match with my router but it still doesn't connect to the internet. I have sucessfully connected to xbmc using filezilla ftp so I can get in.
I am using a router and the ip's are from the router (LAN) and not my ISP.
Hmm has anyone come across this?
In short - The internet is connected when you go /system info/ network & and all the ip's have automatically populated in system configuration/ network but it still comes up says "could not connect to a network server."
Bump
Can anyone help out with the above post? Or should I install 9.04?
Did you set the dns in /etc/resolv.conf?
Maxim Wrote:Did you set the dns in /etc/resolv.conf?
ummmmm... nope havn't touched /etc/resolv.conf
I'll have a look tonight. So how do I set dns?
Put in the file
nameserver 192.168.0.2
Of course replace the IP address with your router or your ISP's DNS.
Maxim Wrote:Put in the fileCode:
Hmm I've tried both, added the file with my router gateway aswell as my ISP DNS but it still doesn't seem to want to connect to the internet
Can I try anything else or is this a fail for me.
