Full Version: Filter Out Genres?
Id like to make a control that filters out a couple of genres & the movies that apply to them. ie Action & Horror
Can this be done in the skin or is it at code level??
have played around with <visibile>! & Substring. for the list info but it does freaky things.
thanks
Use a smartplaylist.
Thanks JM
How do i execute a smartplaylist via a button, (just listing of the smartplaylist,not to start playing it)?
Hmm, good question. I *think* you can do it via ActivateWindow(VideoLibrary,<path_to_smart_playlist>) but I'm not 100 on that.
The path would be something like: special://profile/playlists/video/<name of playlist>.xsp
Give it a whirl anyway and see where you get to. If we have to make some code modifications to get this to work correctly we will.
Cheers,
Jonathan
Can confirm
<onclick>ActivateWindow(VideoLibrary,special://xbmc/userdata/playlists/video/Test.xsp)</onclick>
Works perfectly
Thanks again JM
