Full Version: MS visable but cannot select on xbox
I put the MediaStream folder into my skins directory in the XMBC folder on my XBOX. When I go into XMBC and try to select MS I am unable to do so. I can scroll through my skins and MS is visible but its not white, its gray and I can't select it.
What could be causing this?
Check there's not another MediaStream folder inside that one.
ie XBMC\Skins\MediaStream\MediaStream\
It turns out I was using an older version of XBMC. Updated and now problem solved!
