ruff Wrote:I submitted first patch, it is still being discussed. I'd appreciate if someone else will try it and report back of any issue.
Patch applied without any issue to 48 rel.
ruff@ruff:~/bluez-4.48$ patch -p1 </home/share/fakehid.patch
patching file input/device.c
patching file input/device.h
patching file input/fakehid.c
patching file input/fakehid.h
<snip configure && make && make install>
Making install in input
CC main.lo
CC manager.lo
CC server.lo
CC device.lo
CC fakehid.lo
CCLD input.la
<snip>
root@ruff:~# /opt/bluez/sbin/bluetoothd -nd
bluetoothd[14361]: Bluetooth daemon 4.48
bluetoothd[14361]: Enabling debug information
bluetoothd[14361]: Agent registered for hci0 at :1.688:/org/blueman/agent/adapter/hci0
bluetoothd[14361]: Changing service classes to 0x5a0104
bluetoothd[14361]: ps3remote_out: idle timeout, disconnecting BT channel
bluetoothd[14361]: Input: disconnect /org/bluez/14361/hci0/dev_00_21_4F_B1_F2_79
bluetoothd[14361]: ps3remote_event: Remote unpaired [45:0]
great stuff ruff -
i've successfully patched the 47 build and paired with the remote using blueman. everything works great.
EXCEPT
it unpairs within 1 minute - with the "idle timeout, disconnecting BT channel" message as in your post.
the problem is that i cant get it to re-pair without using the blueman interface again.
how are you doing this? am i missing something?
this is my tail of the daemon log;
Aug 30 22:45:26 couch bluetoothd[6236]: ps3remote_event: Passed key 108:1
Aug 30 22:45:26 couch bluetoothd[6236]: ps3remote_event: Passed key 108:0
Aug 30 22:45:29 couch bluetoothd[6236]: ps3remote_event: Passed key 103:1
Aug 30 22:45:29 couch bluetoothd[6236]: ps3remote_event: Passed key 103:0
Aug 30 22:45:59 couch bluetoothd[6236]: ps3remote_out: idle timeout, disconnecting BT channel
Aug 30 22:45:59 couch bluetoothd[6236]: Input: disconnect /org/bluez/6236/hci0/dev_00_23_06_EC_BC_B4
Aug 30 22:45:59 couch bluetoothd[6236]: ps3remote_event: Remote unpaired [103:0]
Aug 30 22:45:59 couch bluetoothd[6236]: ps3remote_event: Event failed
Aug 30 22:46:14 couch bluetoothd[6236]: adapter_get_device(00:23:06:EC:BC:B4)
Aug 30 22:46:17 couch bluetoothd[6236]: adapter_get_device(00:23:06:EC:BC:B4)
I had a similar problem, simply use the init patch to use correct version of bluetoothd on bootup. Also, unplug the BT stick, and reboot the whole box after fixing the init.. When the box is still booting plug the stick back in. I think some sticks don't like warm boots. Mine keeps blinking even if i stop bluetoothd for example
(Side note: Blueman no longer works, but the ps3 remote is correctly paired after boot/timeouts/etc.)
Asure Wrote:I had a similar problem, simply use the init patch to use correct version of bluetoothd on bootup. Also, unplug the BT stick, and reboot the whole box after fixing the init.. When the box is still booting plug the stick back in. I think some sticks don't like warm boots. Mine keeps blinking even if i stop bluetoothd for example
(Side not: Blueman no longer works, but the ps3 remote is correctly paired after boot/timeouts/etc.)
i figured out why it timed out so fast - the /etc/bluetooth/input.conf file specified 30 for the idle timeout. the comments in the file leave you to believe the unit is in minutes, but clearly its in seconds.
i got that crazy situation where blueman will no longer admin the hci0 anymore after reboot also. not sure why. guessing its because im starting the wrong version of bluez at startup.
thanks for the tip. i will look into this tonight. what init patch are you refering to though?
are you suggesting i patch it manually?
i assume you are refering to /etc/init.d/bluetooth ?
cheers.
ruff, this is awesome. Thanks for going ahead and making the bluez patch... will test it out with the BD Remote on my Zotac ION MythTV front-end in the next few days.
Does the key mapping allow auto-repeat of the BD Remote keys? Since the remote used discrete press/release codes, there doesn't seem to be anyway in lirc to generate soft auto-repeat.... Although I can see that it must be possible in the input driver itself. (Here's a thread of someone trying to accomplish uinput press/release auto-repeat for an ATI remote:
http://www.nabble.com/Re%3A-Linux-input-...#a21203169)
ruff Wrote:yes, with this patch it will disconnect BT channel in IdleTimeout seconds, forcing remote to sleep. If timeout specified less then 5sec (or not specified at all) - default 5min timeout will be enforced.
As for keys - yes, this patch (in posts above) is remapping keys to standard keyboard scancodes, also this mapping resembles XBMC keyboard mapping, thus you don't need to customize keymaps for quick start.
However, key remapping will not be submitted to bluez mainstream, as devs rejected it, stating that current mapping is logical, and new XInput2 is capable to handle it.
Will try to push at least option to choose alternate mapping for compatibility efforts. But after initial timeout will be accepted to mainstream.
databubble Wrote:Does the key mapping allow auto-repeat of the BD Remote keys?
yes, auto repeat works for me.
singleuseonly Wrote:yes, auto repeat works for me.
I applied the patch to bluez 4.50 cleanly, and installed on ubuntu 9.10 alpha. The patch works beautifully for controlling the connection/timeout of the BDRemote.
I'm using the remote with lirc (for controlling MythTV). Only some of the keys were recognized using my previous lircd.conf file. I generated a new one with irrecord (this time using key names from the existing lircd key namespace) and modified my .lircrc file accordingly.
This lird.conf file now looks as follows:
# Please make this file available to others
# by sending it to <[email protected]>
# this config file was automatically generated
# using lirc-0.8.5(devinput) on Thu Sep 3 00:53:10 2009
# contributed by
# brand: PS3.rem
# model no. of remote control:
# devices being controlled by this remote:
begin remote
name SonyBDRemote
bits 8
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 24
pre_data 0x800100
gap 33672
toggle_bit_mask 0x0
begin codes
KEY_0 0x0B
KEY_1 0x02
KEY_2 0x03
KEY_3 0x04
KEY_4 0x05
KEY_5 0x06
KEY_6 0x07
KEY_7 0x08
KEY_8 0x09
KEY_9 0x0A
KEY_EJECTCD 0xA1
KEY_AUDIO 0x1E
KEY_ANGLE 0x2C
KEY_SUBTITLE 0x14
KEY_CLEAR 0x6F
KEY_TIME 0x6B
KEY_RED 0x41
KEY_GREEN 0x42
KEY_BLUE 0x44
KEY_YELLOW 0x43
KEY_VIDEO 0x20
KEY_HOMEPAGE 0x8B
KEY_MENU 0x57
KEY_AB 0x01
KEY_OPTION 0x58
KEY_BACK 0x9E
KEY_INFO 0x2F
KEY_DELETE 0x2D
KEY_UP 0x67
KEY_DOWN 0x6C
KEY_LEFT 0x69
KEY_RIGHT 0x6A
KEY_ENTER 0x1C
KEY_RECORD 0xAC
KEY_SELECT 0x6E
KEY_RESTART 0x66
KEY_PAGEUP 0x3B
KEY_PAGEDOWN 0x3E
KEY_HOME 0x3C
KEY_END 0x3F
KEY_VOLUMEDOWN 0x3D
KEY_VOLUMEUP 0x40
KEY_PLAY 0xCF
KEY_STOP 0x80
KEY_PAUSE 0xA4
KEY_REWIND 0x13
KEY_FASTFORWARD 0x21
KEY_PREVIOUS 0x6D
KEY_NEXT 0x68
KEY_SCROLLDOWN 0x33
KEY_SCROLLUP 0x34
end codes
end remote
This file only contains the key depress events. Instead of repeating, the BDRemote has separate events for key depress / key release.
My only trouble now is trying to enable auto-repeat via lirc or the linux event driver. I presume XBMC is not using lirc, and is taking care of the autorepeat internally somehow.
Anyone have any idea how to generate key autorepeats that can be used with lirc?
Does anyone know the process of pairing the remote on the command-line? I have bluez-4.50 patched with the keycode patch and powersaving patch and it can discover the remote with this:
hcitool scan
It gives me the mac address but I'm not sure what to do next to get it to pair if that's even needed. bluez-4.50 doesn't have the hidd command anymore.
databubble Wrote:My only trouble now is trying to enable auto-repeat via lirc or the linux event driver. I presume XBMC is not using lirc, and is taking care of the autorepeat internally somehow.
Autorepeat is done inside input keyboard driver. PS3BD uinput driver is just sending key-press and key-release events, input is then sending keycodes/scancodes and repeating them. That actually caused that problem with event device handler locking when unpairing with ps button hold (keypress is sent but keyrelease is not - thus input is locked in repeating keycode).
Now, since ps3remote is seen as simple keyboard, and mythtv is capable to be controlled from keyboard - you don't need lirc, just map keys as you wish
http://tips.myhdbox.com/2006/04/tip-1-my...eature.php
Here is mapping with key patch
eject-cd 1 2 3
a 4 5 6
z 7 8 9
t DEL 0 END
F7 F8 F9 F10
d Menu F11 Esc
F12 Up Back
Left Enter Right
v Down x
F1 HomePage F4
F2 F5
F3 Ins Home F6
r Play f
PageDown Stop PageUp
, Play-Pause .
Ruff: passkey-agent doesn't appear to exist in bluez-4.50. What has it been replaced with?
I found some directions on how to pair but I don't know where to get the passkey-agent equivalent:
passkey-agent –default /usr/bin/bluez-pin
hcitool scan
hcitool cc
hcitool auth
http://wiki.bluez.org/wiki/HOWTO/Bonding
Quote:Manually insert a pin
my copy of the man page for bluetoothd is missing this:
/var/lib/bluetooth/nn:nn:nn:nn:nn:nn/pincodes
Default location for pins for pairing devices. The file is line separated, with the following columns separated by whitespace:
nn:nn:nn:nn:nn:nn Remote device address.
n 1-8 digit pin code. User may have to consult hardware documentation in cases of hard coded pins. Try 0000
2008-10-03 Marcel Holtmann Remove old passkey-agent and auth-agent
Ruff: I think I have it bonded now. I installed blueman to see what it's doing an I saw that it brings up the hci0 interface with page and inquiry scan enabled.
So that's as simple as running this command line:
hciconfig hci0 up piscan
Then when you type hciconfig again, you should see this:
hci0: Type: USB
BD Address: 00:1E:58:3F:64:CD ACL MTU: 384:8 SCO MTU: 64:8
UP RUNNING PSCAN ISCAN
RX bytes:15010 acl:184 sco:0 events:574 errors:0
TX bytes:5839 acl:253 sco:0 commands:149 errors:0
If both page scan and inquiry scan aren't enabled, the bdremote won't communicate with the dongle.
Then now I have hcidump running in a console and when I press a key, it is detected and throws up something like this when pressing the play button:
> HCI Event: Connect Request (0x04) plen 10
< HCI Command: Accept Connection Request (0x01|0x0009) plen 7
> HCI Event: Command Status (0x0f) plen 4
> HCI Event: Role Change (0x12) plen 8
> HCI Event: Connect Complete (0x03) plen 11
> ACL data: handle 42 flags 0x02 dlen 12
L2CAP(s): Connect req: psm 17 scid 0x00ff
< HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2
< ACL data: handle 42 flags 0x02 dlen 16
L2CAP(s): Connect rsp: dcid 0x0040 scid 0x00ff result 1 status 0
Connection pending - No futher information available
< ACL data: handle 42 flags 0x02 dlen 10
L2CAP(s): Info req: type 2
> HCI Event: Page Scan Repetition Mode Change (0x20) plen 7
> HCI Event: Number of Completed Packets (0x13) plen 5
< HCI Command: Remote Name Request (0x01|0x0019) plen 10
L2CAP(s): Info rsp: type 2 result 0
Extended feature mask 0x0004
L2CAP(s): Connect rsp: dcid 0x0040 scid 0x00ff result 0 status 0
Connection successful
> HCI Event: Read Remote Supported Features (0x0b) plen 11
L2CAP(s): Config req: dcid 0x0040 flags 0x00 clen 4
MTU 185
< ACL data: handle 42 flags 0x02 dlen 18
L2CAP(s): Config rsp: scid 0x00ff flags 0x00 result 0 clen 4
MTU 185
< ACL data: handle 42 flags 0x02 dlen 12
L2CAP(s): Config req: dcid 0x00ff flags 0x00 clen 0
L2CAP(s): Config rsp: scid 0x0040 flags 0x00 result 0 clen 4
MTU 185
< ACL data: handle 42 flags 0x02 dlen 5
L2CAP(d): cid 0x00ff len 1 [psm 17]
HIDP: Control: Virtual cable unplug
L2CAP(s): Disconn req: dcid 0x00ff scid 0x0040
L2CAP(s): Connect req: psm 19 scid 0x0100
L2CAP(s): Connect rsp: dcid 0x0041 scid 0x0100 result 1 status 2
Connection pending - Authorization pending
L2CAP(s): Connect rsp: dcid 0x0041 scid 0x0100 result 3 status 0
Connection refused - security block
L2CAP(s): Disconn req: dcid 0x0040 scid 0x00ff
L2CAP(s): Disconn rsp: dcid 0x0040 scid 0x00ff
L2CAP(s): Disconn req: dcid 0x0041 scid 0x0100
L2CAP(s): Disconn rsp: dcid 0x0041 scid 0x0100
L2CAP(s): Disconn rsp: dcid 0x00ff scid 0x0040
> HCI Event: Remote Name Req Complete (0x07) plen 255
< HCI Command: Read Remote Version Information (0x01|0x001d) plen 2
> HCI Event: Disconn Complete (0x05) plen 4
> HCI Event: Read Remote Ver Info Complete (0x0c) plen 8
The strange thing I've noticed though is lsinput does not list the bdremote as an input device. I know people have previously mentioned that they could see it there but is it necessary to see it there even with your patches?
So at this point I know the remote is communicating with the dongle and I'm wondering how to translate that to keypresses in mythtv.
not sure how lsinput works, however, as it was already mentioned, you should see device in proc bus input list, like this
root@ruff:~# cat /proc/bus/input/devices | grep Name
N: Name="Power Button (FF)"
N: Name="Power Button (CM)"
N: Name="Macintosh mouse button emulation"
N: Name="Logitech Logitech Cordless RumblePad 2"
N: Name="PC Speaker"
N: Name="PS3 Remote Controller"
also, if running daemon in debug mode, you should see such events during pairing
bluetoothd[5117]: adapter_get_device(00:21:4F:F1:B2:07)
bluetoothd[5117]: Incoming connection on PSM 17
bluetoothd[5117]: Incoming connection on PSM 19
bluetoothd[5117]: ps3remote_setup_uinput: input 20 is opened
Last line - if patch was applied
Ruff: I applied both your bdremote and powersave patch but I don't get that. lsinput lists similar info as cat /proc/bus/input/devices. Here's my output for cat /proc/bus/input/devices | grep Name:
N: Name="Power Button"
N: Name="Sleep Button"
N: Name="Microsoft Natural� Ergonomic Keyboard 4000"
N: Name="Logitech USB-PS/2 Optical Mouse"
This is while I have the dongle plugged in and keypresses generate dump signals to hcidump.
Ruff: This is what I get when I plug the bluetooth dongle in in /var/log/messages:
Sep 6 16:18:58 aragorn bluetoothd[2853]: Bluetooth daemon 4.50
Sep 6 16:18:58 aragorn bluetoothd[2856]: Starting SDP server
Sep 6 16:18:58 aragorn bluetoothd[2856]: Starting experimental netlink support
Sep 6 16:18:58 aragorn bluetoothd[2856]: Failed to find Bluetooth netlink family
Sep 6 16:18:58 aragorn bluetoothd[2856]: Failed to init netlink plugin
Sep 6 16:18:58 aragorn bluetoothd[2856]: Can't create GN bridge
Sep 6 16:18:58 aragorn bluetoothd[2856]: HCI dev 0 registered
Sep 6 16:18:58 aragorn bluetoothd[2856]: Failed to open RFKILL control device
Sep 6 16:18:58 aragorn bluetoothd[2856]: HCI dev 0 up
Sep 6 16:18:58 aragorn bluetoothd[2856]: Starting security manager 0
Sep 6 16:18:59 aragorn bluetoothd[2856]: Parsing /etc/bluetooth/serial.conf failed: No such file or directory
Sep 6 16:18:59 aragorn bluetoothd[2856]: Adapter /org/bluez/2853/hci0 has been enabled
Ruff: Here's a short copy of the build.log when I'm applying your patches:
>>> Unpacking source...
>>> Unpacking bluez-4.50.tar.gz to /var/tmp/portage/net-wireless/bluez-4.50/work
>>> Source unpacked in /var/tmp/portage/net-wireless/bluez-4.50/work
>>> Preparing source in /var/tmp/portage/net-wireless/bluez-4.50/work/bluez-4.50 ...
[32;01m*[0m Applying bluez-plugdev.patch ...
[A[147C [34;01m[ [32;01mok[34;01m ][0m
[32;01m*[0m Applying 4.50-conditional-libsbc.patch ...
[32;01m*[0m Applying 4.50-cups-location.patch ...
[32;01m*[0m Applying bdremote.patch ...
[32;01m*[0m Applying powersave.patch ...
[32;01m*[0m Running eautoreconf in '/var/tmp/portage/net-wireless/bluez-4.50/work/bluez-4.50' ...
[32;01m*[0m Running aclocal ...
[32;01m*[0m Running libtoolize --copy --force --automake ...
[32;01m*[0m Running autoconf ...
[32;01m*[0m Running autoheader ...
[32;01m*[0m Running automake --add-missing --copy ...
[32;01m*[0m Running elibtoolize in: bluez-4.50
[32;01m*[0m Applying portage-1.5.10.patch ...
[32;01m*[0m Applying sed-1.5.6.patch ...
[32;01m*[0m Applying as-needed-1.5.26.patch ...
>>> Source prepared.
>>> Configuring source in /var/tmp/portage/net-wireless/bluez-4.50/work/bluez-4.50 ...
* econf: updating bluez-4.50/config.guess with /usr/share/gnuconfig/config.guess
* econf: updating bluez-4.50/config.sub with /usr/share/gnuconfig/config.sub
./configure --prefix=/usr --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --enable-network --enable-serial --enable-input --enable-audio --enable-service --enable-gstreamer --enable-alsa --enable-usb --enable-netlink --enable-tools --enable-bccmd --enable-hid2hci --enable-dfutool --disable-hidd --disable-pand --disable-dund --enable-cups --disable-test --enable-udevrules --enable-configfiles --disable-pcmcia --disable-debug --localstatedir=/var
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for i686-pc-linux-gnu-pkg-config... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for i686-pc-linux-gnu-gcc... i686-pc-linux-gnu-gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether i686-pc-linux-gnu-gcc accepts -g... yes
checking for i686-pc-linux-gnu-gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of i686-pc-linux-gnu-gcc... gcc3
checking whether i686-pc-linux-gnu-gcc and cc understand -c and -o together... yes
checking whether i686-pc-linux-gnu-gcc accepts -fPIE... yes
checking for bison... bison -y
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by i686-pc-linux-gnu-gcc... /usr/i686-pc-linux-gnu/bin/ld
checking if the linker (/usr/i686-pc-linux-gnu/bin/ld) is GNU ld... yes
checking for /usr/i686-pc-linux-gnu/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... i686-pc-linux-gnu-gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 1572864
checking command to parse /usr/bin/nm -B output from i686-pc-linux-gnu-gcc object... ok
checking for objdir... .libs
checking for i686-pc-linux-gnu-ar... i686-pc-linux-gnu-ar
checking for i686-pc-linux-gnu-ranlib... i686-pc-linux-gnu-ranlib
checking for i686-pc-linux-gnu-strip... i686-pc-linux-gnu-strip
checking for correct ltmain.sh version... yes
checking if i686-pc-linux-gnu-gcc supports -fno-rtti -fno-exceptions... no
checking for i686-pc-linux-gnu-gcc option to produce PIC... -fPIC
checking if i686-pc-linux-gnu-gcc PIC flag -fPIC works... yes
checking if i686-pc-linux-gnu-gcc static flag -static works... yes
checking if i686-pc-linux-gnu-gcc supports -c -o file.o... yes
checking whether the i686-pc-linux-gnu-gcc linker (/usr/i686-pc-linux-gnu/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
checking for ppoll... yes
checking for dlopen in -ldl... yes
checking for DBUS... yes
checking for dbus_watch_get_unix_fd in -ldbus-1... yes
checking for GLIB... yes
checking for ALSA... yes
checking for clock_gettime in -lrt... yes
checking for GSTREAMER... yes
checking for USB... yes
checking for usb_get_busses in -lusb... yes
checking for usb_interrupt_read in -lusb... yes
checking for NETLINK... yes
checking for SNDFILE... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating scripts/bluetooth.rules
config.status: creating doc/version.xml
config.status: creating src/bluetoothd.8
config.status: creating bluez.pc
config.status: creating config.h
config.status: executing depfiles commands
>>> Source configured.
>>> Compiling source in /var/tmp/portage/net-wireless/bluez-4.50/work
--- /etc/
--- /etc/alsa/
>>> /etc/alsa/bluetooth.conf
--- /etc/dbus-1/
--- /etc/dbus-1/system.d/
>>> /etc/dbus-1/system.d/bluetooth.conf
--- /etc/bluetooth/
--- /etc/bluetooth/rfcomm.conf
>>> /etc/bluetooth/network.conf
>>> /etc/bluetooth/main.conf
--- /etc/bluetooth/input.conf
>>> /etc/bluetooth/audio.conf
--- /lib/
--- /lib/udev/
--- /lib/udev/rules.d/
>>> /lib/udev/rules.d/97-bluetooth.rules
>>> /lib/udev/rules.d/97-bluetooth-hid2hci.rules
--- /var/
--- /var/lib/
--- /var/lib/bluetooth/
--- /usr/
--- /usr/bin/
>>> /usr/bin/dfutool
>>> /usr/bin/sdptool
>>> /usr/bin/l2ping
>>> /usr/bin/hcitool
>>> /usr/bin/rfcomm
>>> /usr/bin/ciptool
--- /usr/lib/
>>> /usr/lib/libbluetooth.so -> libbluetooth.so.3.3.0
--- /usr/lib/pkgconfig/
>>> /usr/lib/pkgconfig/bluez.pc
>>> /usr/lib/libbluetooth.so.3.3.0
--- /usr/lib/gstreamer-0.10/
>>> /usr/lib/gstreamer-0.10/libgstbluetooth.so
--- /usr/lib/bluetooth/
--- /usr/lib/bluetooth/plugins/
>>> /usr/lib/bluetooth/plugins/netlink.so
--- /usr/lib/alsa-lib/
>>> /usr/lib/alsa-lib/libasound_module_ctl_bluetooth.so
>>> /usr/lib/alsa-lib/libasound_module_pcm_bluetooth.so
>>> /usr/lib/libbluetooth.so.3 -> libbluetooth.so.3.3.0
--- /usr/sbin/
>>> /usr/sbin/hciattach
>>> /usr/sbin/bccmd
>>> /usr/sbin/hciconfig
>>> /usr/sbin/hid2hci
>>> /usr/sbin/bluetoothd
--- /usr/share/
--- /usr/share/doc/
--- /usr/share/doc/bluez-4.50/
>>> /usr/share/doc/bluez-4.50/AUTHORS.bz2
>>> /usr/share/doc/bluez-4.50/README.bz2
>>> /usr/share/doc/bluez-4.50/ChangeLog.bz2
--- /usr/share/man/
--- /usr/share/man/man1/
>>> /usr/share/man/man1/hcitool.1.bz2
>>> /usr/share/man/man1/dfutool.1.bz2
>>> /usr/share/man/man1/rfcomm.1.bz2
>>> /usr/share/man/man1/ciptool.1.bz2
>>> /usr/share/man/man1/dfubabel.1.bz2
>>> /usr/share/man/man1/sdptool.1.bz2
--- /usr/share/man/man8/
>>> /usr/share/man/man8/l2ping.8.bz2
>>> /usr/share/man/man8/hciconfig.8.bz2
>>> /usr/share/man/man8/bccmd.8.bz2
>>> /usr/share/man/man8/avctrl.8.bz2
>>> /usr/share/man/man8/hciattach.8.bz2
>>> /usr/share/man/man8/bluetoothd.8.bz2
>>> /usr/share/man/man8/hid2hci.8.bz2
--- /usr/libexec/
--- /usr/libexec/cups/
--- /usr/libexec/cups/backend/
>>> /usr/libexec/cups/backend/bluetooth
--- /usr/include/
--- /usr/include/bluetooth/
>>> /usr/include/bluetooth/sdp_lib.h
>>> /usr/include/bluetooth/hci_lib.h
>>> /usr/include/bluetooth/rfcomm.h
>>> /usr/include/bluetooth/hci.h
>>> /usr/include/bluetooth/sco.h
>>> /usr/include/bluetooth/sdp.h
>>> /usr/include/bluetooth/bluetooth.h
>>> /usr/include/bluetooth/bnep.h
>>> /usr/include/bluetooth/cmtp.h
>>> /usr/include/bluetooth/hidp.h
>>> /usr/include/bluetooth/l2cap.h
>>> Regenerating /etc/ld.so.cache...
