Full Version: Open videos with a click
Hi
I noticed this in the FAQ:
Quote:When I switch to library mode, the next time it's back to file mode. Or vice versa.
- On the homescreen pressing one of the menu items takes you to the file mode categories. When hovered on for example "videos" press the direction down button to access a submenu with various library related functions.
I kept accidentally hitting select instead of down so I edited the Home.xml to open the sub-menu when clicked (like it does when you press down).
In case anyone else has this problem, just find this bit in PAL/Home.xml that reads:
        <control type="button" id="1">
            <label>3</label>
            <posx>0</posx>
            <posy>0</posy>
            <onleft>6</onleft>
            <onright>2</onright>
            <onup>6</onup>
            <ondown>1100</ondown>
            <width>100</width>
            <height>44</height>
            <texturefocus>default-button.png</texturefocus>
            <texturenofocus>-</texturenofocus>
            <font>menubar</font>
            <textcolor>button-text</textcolor>
            <aligny>-</aligny>
            <align>center</align>
            <textoffsety>1</textoffsety>
            <onclick>ActivateWindow(MyVideoFiles)</onclick>
        </control>
And change it to:
            <label>3</label>
            <posx>0</posx>
            <posy>0</posy>
            <onleft>6</onleft>
            <onup>6</onup>
            <width>100</width>
            <height>44</height>
            <aligny>-</aligny>
            <onclick>SetFocus(1100)</onclick>
        </control>
Hope this helps someone
Regards
Tom
