Full Version: [atv] atlantis to babylon upgrade, library no longer working (sqlite problem?)
I have just updated my atv from Atlantas to Babylon (bf1) using the launcher menu, and now have issues trying to playback any file from the library.
From the video library mode, if i select TV Shows, then Genres / Title / Year / Actors - nothing happens, no error, no time out. The same is repeated if I try with the Movie Library.
Another interesting point, I try to load the recently added movies / episode option, i do get an error "Remote Share: Path not found or invalid".
The only thing that has been done is xbmc has been upgraded. All paths / shares are then same as before the upgrade, so I suspect the library has become corrupt.
If i access xbmc through the web interface, it is still able to access, browse and playback from the remote shares - again making me think the library is corrupt?
I've looked through the log and there seems to be a problem updating the db:
10:29:34 T:2684407808 M: 27324416 ERROR: Can't update the database MyVideos34.db from version 22 to 25
10:30:12 T:2684407808 M: 27320320 NOTICE: Attempting to update the database MyVideos34.db from version 22 to 25
10:30:12 T:2684407808 M: 27324416 ERROR: SQLite: SQL error or missing database
Query: alter table path add noUpdate bool
10:30:12 T:2684407808 M: 27324416 ERROR: Error attempting to update the database version!
This error is repeated a few times, is there a manual way of updating this without recreating the db from scratch? I really want to recover the existing library data, as i have about 20k items in it, and don't want to have to go through setting the watched status for all of them again!
I've had a quick look and it seems other people may be having a similar issues, is there a way to recover this?
All help appreciated Smile
2. Platform - AppleTV - Darwin AppleTV-2.local 8.8.2 Darwin Kernel Version 8.8.2: Mon Jan 29 18:57:29 PST 2007; root:xnu-792.94.18~1/RELEASE_I386 i386 i386
3. Arch: i386
4. Install method - Launcher Menu
5. SVN Revision - xbmc 9.04 r19840
6. Details to reproduce - Details above
7. Debug Log - http://pastebin.com/m41c85794
8. Backtrace - n/a
9. Compiler Output - n/a
As stated elsewhere on the forums, it's a known problem with Babylon RC1 and below. It was fixed in the final Babylon release - grab that one and all will be peachy.
Cheers,
Jonathan
Sorry, i thought i had updated to babylon final and still had the problem.
Have reupdated again, and all seems fine now.
thanks
