Full Version: Apple Trailers text showing through...
http://www.freewebs.com/directory/screenshot000.bmp
Any ideas on an easy fix? Smile Is it as simple as telling it to be behind a layer? Or is it something wrong with the script? Forgive my noobiness Smile
Thanks in advance!
-Erik
Edit: Oh ya, this is latest MC360, downloaded from link in thread below it is dated 5-11... Xbox is the platform and I am running a fresh install of the latest Babylon...
First off please don't post BMP image, PNG and JPG are much nicer for the internet (so I changed it to a link)
Second HMMMMMMMMMMMM I thought I fixed that ages ago will look into it
here you go replace this file in the PAL folder of the skin should fix it (rightclick save as)
https://xboxmediacenter.svn.sourceforge....s-main.xml
First of thanks for the quick response and sorry about the bmp Smile here is a png of another issue Smile
this time with the youtube script...
See below for working script
Thanks again!
-Erik
Also, where is the startup file location stored? I would like xbmc to startup in a certain folder...
-Erik
burritoboy9984 Wrote:here is a png of another issue Smile
[img]
Thanks again!
-Erik
What version youtube script is this? Afaik the latest is Youtube 3.4 and it doesn't have a working MC360 skin included. I've made one that works, though it's not sized properly for widescreen.
http://www.turboupload.com/6ubytmel4r9r/...n.zip.html
Ya, after thinking, I just copied over the youtube 3.4 script and it worked like a champ Smile
What exactly is the Black Market Themes, it crashes everytime I load it... here is debug Smile
20:48:04 M: 24752128 INFO: Loading skin includes from Q:\skin\MC360\extras\XBMCBlackMarket\resources\resources\skins\MC360\includes.xml
20:48:04 M: 24731648 INFO: Error loading includes.xml file (Q:\skin\MC360\extras\XBMCBlackMarket\resources\resources\skins\MC360\includes.xml): Failed to open file (row=0, col=0)
20:48:04 M: 24715264 NOTICE: Traceback (most recent call last):
20:48:04 M: 24682496 NOTICE: File "Q:\skin\MC360\extras\XBMCBlackMarket\default.py", line 43, in ?
20:48:04 M: 24702976 NOTICE: ui = main.ThemeBrowser('script-%s-%s.xml' % ( __scriptname__.replace( ' ', '_' ), window, ), BASE_RESOURCE_PATH, currentSkin )
20:48:04 M: 24735744 NOTICE: TypeError
20:48:04 M: 24715264 NOTICE: :
20:48:04 M: 24715264 NOTICE: XML File for Window is missing
20:48:04 M: 24666112 ERROR: Scriptresult: Error
20:48:04 M: 24666112 INFO: Loading skin file: DialogOK.xml
20:48:04 M: 24649728 DEBUG: Load DialogOK.xml: 29.93ms
20:48:04 M: 24375296 DEBUG: Alloc resources: 10.73ms (0.00 ms skin load, 0.27 ms preload)
P.S. I LOVE this skin... very nice work Smile
-Erik
people actually use apple trailers? for what?
osmorphyus Wrote:people actually use apple trailers? for what?
If you can't guess, I hope no one tells you.
way to drag up a 5 month old post but
FOR WATCHING TRAILERS would be my first guess
