Full Version: mts files with 9.04 have NO sound
I have said this before when it was in beta but 9.04 does NOT play .mts (avchd) files correctly anymore. The audio is gone.
if I reload 8.10 its there if I load 9.04 its gone ... I put 8.10 back and all is well.
yes I checked my sound settings , other type files have audio just fine ... its only when I play native .mts files , you get the video with no audio.
can anyone else please take a .mts file from their avchd camera and play it back to verify ?
jhillestad Wrote:I have said this before when it was in beta but 9.04 does NOT play .mts (avchd) files correctly anymore. The audio is gone.
need a sample clip to verify.
davilla Wrote:need a sample clip to verify.
ok , I put a small 8mb .mts file for you on my idisk , its just a small clip
http://files.me.com/hillestad/dsy5ax
jhillestad Wrote:ok , I put a small 8mb .mts file for you on my idisk , its just a small clip
thanks, there's some sort of ffmpeg regression going on.
Thanks Davilla for looking into it !!!! xbmc is the only program I use to sample my avchd files natively and I was bummed out when the latest version had a problem...
