Full Version: Cyberlink Remote Control
Hi
Yesterday, I have just bought this remote control (Cyberlink) [http://www.scanmalta.com/item.php?WebCat...CC-L19459]. It works fine even on Linux. My only issue is the [BACK] button which only works in certain areas.
For example:
I am watching a film. I stop the film, then press the [BACK] button which does the same work as pressing the [ESC] button to go back to the menus. That works perfect.
The issue is when for example
I was in the Settings menu, I changed some settings and I want to go back. At this point it doesn't work. I have to go and press the [ESC] button from the keyboard.
I am finding it a little bit inconvenient. Is there any possibility to make this works?
I am running XBMC using the live CD at the moment. I have installed it on a test machine but it didn't work either.
tbh I am surprised you got it working...
Look in the LIVE section there are 3 threads on that remote. With a link to an app that helps it work.
Best bet is return it and get a different remote.
All I need is to make the BACK button works in all menus. Can you help me please? What do I have to change. If you can guide me step by step I'd really appreciate it since I am new to Linux/XBMC
As I said search the LIVE section there are a few threads there on that remote which may help.
