Full Version: Are there instructions for trying/installing new SVN releases on AppleTV
I see there are nightly updates for testing.
How do you do an install?
I see the kit seems to have a folder structure at the same structure as on the ATV. Do I just ftp the folders from XBMC.App down into the Applications folder on the ATV, after removing the old XMBC.App folder?
Do I need to restart the ATV after?
philhu Wrote:I see there are nightly updates for testing.
I see the kit seems to have a folder structure at the same structure as on the ATV. Do I just ftp the folders from XBMC.App down into the Applications folder on the ATV, after removing the old XBMC.App folder?
just replace the old xbmc.app with the new. make sure you are NOT running xbmc when replacing. A restart of the AppleTV is NOT required.
New to Mac
You mean the XBMC.app folder
XBMP.app is really a folder containing all the app items, correct?
philhu Wrote:New to Mac
On OSX and folder with a ".app" extension is considered an Application container. Make sure you copy the entire directory.
