tdw197 Wrote:I have a rather bizarre problem.
I have just updated my xbmclive dharma to pre Eden. The plugin works, but any stream plays with the bottom 1/8 of the screen distorted.
Anyone else seen this?
Yeah i get this sometimes - 20% of the time, can't make it go away. Next day all is fine again (i'm Eden on OpenElec)
Jon
tdw197 Wrote:Yes, like that.
Guess you didn't find a solution? It starts off as bizarre green artefacts/interference at bottom of screen.
No, Prof Yaffle is working at it
http://forum.xbmc.org/showthread.php?tid=99448
I've settled for stream quality set @1500k because I've only had problems with HD streams.
I love this addon!
But it wont skip through radio shows - you have to listen from start to finish.
down for me now
EDIT: Back up now
I'm getting the iPlayer add-on/XBMC freezing about 10 seconds after resuming from a pause on all the programs I've tried.
I'm running W7 x64, with the iPlayer add-on from the Hitcher's repository (I assume that's the most up to date version).
22:39:32 T:3472 M:841826304 WARNING: CDVDPlayer::CheckContinuity - wrapback of stream:2, prev:18400000.000000, curr:18360000.000000, diff:-40000.000000
22:39:32 T:3472 M:841715712 NOTICE: Opening audio stream: 1 source: 256
22:39:32 T:3472 M:841576448 NOTICE: Closing audio stream
22:39:32 T:3472 M:841576448 NOTICE: Waiting for audio thread to exit
22:39:32 T:1820 M:841576448 NOTICE: thread end: CDVDPlayerAudio::OnExit()
22:39:32 T:3472 M:841617408 NOTICE: Closing audio device
22:39:32 T:3472 M:841519104 NOTICE: Deleting audio codec
22:39:32 T:3472 M:841449472 NOTICE: Finding audio codec for: 86018
22:39:32 T:3472 M:841261056 NOTICE: Creating audio thread
22:39:32 T:2760 M:841261056 NOTICE: running thread: CDVDPlayerAudio::Process()
22:39:32 T:2760 M:841261056 NOTICE: Creating audio device with codec id: 86018, channels: 2, sample rate: 48000, no pass-through
22:39:33 T:2760 M:841031680 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
22:39:34 T:4388 M:838582272 WARNING: Previous line repeats 2 times.
22:39:34 T:4388 M:838582272 WARNING: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video didn't consume the full packet. size: 6601, consumed: 0
22:39:34 T:4388 M:838582272 WARNING: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video didn't consume the full packet. size: 6502, consumed: 0
22:39:34 T:4388 M:837373952 WARNING: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video didn't consume the full packet. size: 8758, consumed: 0
22:39:43 T:4388 M:839376896 WARNING: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video didn't consume the full packet. size: 6702, consumed: 0
22:39:43 T:4388 M:839376896 WARNING: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video didn't consume the full packet. size: 6938, consumed: 0
22:39:44 T:4388 M:839376896 WARNING: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video didn't consume the full packet. size: 4856, consumed: 0
22:39:44 T:4388 M:839376896 WARNING: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video didn't consume the full packet. size: 4922, consumed: 0
22:39:53 T:2760 M:839532544 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
22:39:54 T:4388 M:839987200 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
So it was paused before this log extract begins; I unpause it at 22:39:32, then it appears to run out of buffered content at 22:39:44. From there it stops responding and Windows ends up terminating its task.
I tried searching the forum for this problem, but I've not found much. Apologies if this is a known issue and I've not found the workaround.
Can post more log file if required.
thankyousam Wrote:I'm getting the iPlayer add-on/XBMC freezing about 10 seconds after resuming from a pause on all the programs I've tried.
don't use pause
if you had googled for "xbmc iplayer freeze pause", you would have found a reference for if on the iplayer google code page, but it isn't a plugin issue anyway but related to an interaction between xbmc and librtmp pause functionality - see
http://trac.xbmc.org/ticket/11122
exobuzz Wrote:don't use pause
if you had googled for "xbmc iplayer freeze pause", you would have found a reference for if on the iplayer google code page, but it isn't a plugin issue anyway but related to an interaction between xbmc and librtmp pause functionality - see http://trac.xbmc.org/ticket/11122
Thanks for the link. My Google search went from being too specific, to being too vague, so I didn't find it for myself.
Has anyone noticed, if you pause an iplayer stream, and then resume, it will have a lot of trouble doing so. I actually have to end task on xbmc to get out of this state. Could this be given a look?
PantsOnFire Wrote:Has anyone noticed, if you pause an iplayer stream, and then resume, it will have a lot of trouble doing so. I actually have to end task on xbmc to get out of this state. Could this be given a look?
Isn't your issue dealt with in the post just before yours?
See Exobuzz's reply 4 above this one with the bug/issue link.
FWIW Windows 7 seems to be able to recover XBMC from the freeze for me, but this might be a restart in the background.
d'oh, should have read.
So it looks like a long-standing problem really... I won't worry about it for now then. nice enough to have iplayer at all :-)
I'm new to XBMC. Just downloaded it for Windows - it looks great. I've downloaded, unzipped and put this plugin in the addons folder. I can go through the video menu and get the iplayer plugin to work.
However, when I go through Video, Add Source, Browse - there is no option to add a video plugin. What am I missing?
I have watched the youtube tutorial and searched these forums... I must be missing something!
Please help!
Hi all,
great plugin, thanks for the hard work, I have been using it for a week or so now.
I am running apple tv2, nightly build and the latest version of the plugin.
I am based in the Czech Republic but am using a UK proxy from hideipvpn.com.
The iPlayer plugin works, but it seems that only the latest episodes play properly (and when they play, they play perfectly). Is there a rational explaination for this, and even a work around for it, before I start digging into log files etc?
Thanks all
J
i had this problem with iplayer, but for me it was absolutly random of which would play and which wouldnt. Sometimes i found a show would not play tried a hour later and it played.
