If you are not providing plugin for xbmc, then you should not spam xbmc forums to advertise your website.
(2012-07-15, 16:18)sajjad123 Wrote: [ -> ]Watch India Tv channels, Pakistani Channels, Sports Channels Live Online, Latest Bollywood Movies and Much More On
http://funtv4u.com/
And Latest Hindi Movies Cocktail (2012) Watch Online..
http://funtv4u.com/bollywood-movies/
I'm having an issue with the Watch Live TV streams. They work perfectly when accessing them through the menus, i.e.
iPlayer ->
TV ->
Watch Live -> BBC One, but I tried adding each station as a favourite, and when clicking on the favourite the whole system hangs and needs a reboot.
I've got a debug log:
http://pastebin.com/BBtnfib9
Thanks to anyone who can help.
Hello All,
Related issue here with iPlayer plug-in on ATV2. Recorded streams work fine but live does not. Log is
here.
thanks!
Neither of those logs have any useful information im afraid. things that make the system hang should be reported to xbmc. the plugin just gets urls for xbmc to play.
(2012-07-19, 05:08)ykhehra1 Wrote: [ -> ]If you are not providing plugin for xbmc, then you should not spam xbmc forums to advertise your website.
or have people reply to spammers quoting their spam links so when their accounts/posts are removed, the quoted text remains
I haven't used iPlayer for a while.
I can only get live streams for BBC 3, 4, Alba, Parliament. All the others produce a script error ...
Any ideas?
edit: Doh! Didn't have the latest version - working now!!
Great plugin – been using it for a while – I am not in the UK and use unblock-us and it works great.
The livestreams dont play anymore (they did 4 months ago)- the only one that works is BBC parliament
Below is the error (didn’t want to do pastbin for only two lines)
20:27:28 T:151498752 WARNING: HandShake: Type mismatch: client sent 3, server answered 60
20:27:28 T:151498752 ERROR: RTMP_Connect1, handshake failed.
Anyone know of a workaround?
Thanks in advance
I'm having similar problem the prerecorded shows works fine. Streaming anything but parlement fails with the following error:
00:07:06 T:16513696 ERROR: Playlist Player: skipping unplayable item: 0, path [rtmpt://bbcmedia.fc.llnwd.net:80/ app=bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc4_inlet_480&et=1343725542&fmta-token=5ca322a8cc1e5f4b2e26ba8196adfd3e7da57f377841e6706bae0cf04ea3a76e tcurl=rtmpt://bbcmedia.fc.llnwd.net:80/bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc4_inlet_480&et=1343725542&fmta-token=5ca322a8cc1e5f4b2e26ba8196adfd3e7da57f377841e6706bae0cf04ea3a76e playpath=s_bbc4_inlet_480 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=1 live=1]
I am also getting errors when trying to live stream anything, but parliament. Recorded shows seem to work except on bbc one. I have the latest version and am using usunblock. Everything works on iplayer in my browser. I tried switching between limelight and auto as well
(2012-08-01, 04:35)abc123 Wrote: [ -> ]I am also getting errors when trying to live stream anything, but parliament. Recorded shows seem to work except on bbc one. I have the latest version and am using usunblock. Everything works on iplayer in my browser. I tried switching between limelight and auto as well
will not work with unblock us (xbmc) - you need a vpn for the live stuff - unblockus will not support it on xbmc
(2012-08-01, 19:28)cablegoon Wrote: [ -> ]will not work with unblock us (xbmc) - you need a vpn for the live stuff - unblockus will not support it on xbmc
Ahh okay, looks like Ill have to go back to a vpn, tvcatchup wont work with it either.
... and tvcatchup won't work with a vpn either!
Hi is there any hope of an 'export program to library' function, like in the Hulu plugin?
It could work through the iPlayer 'TV Favourites' function, or maybe could just export from categories, like the popular BBC 1 category, or the entire BBC HD channel.
Thanks for your effort with this excellent plugin.
(2012-08-01, 19:28)cablegoon Wrote: [ -> ] (2012-08-01, 04:35)abc123 Wrote: [ -> ]I am also getting errors when trying to live stream anything, but parliament. Recorded shows seem to work except on bbc one. I have the latest version and am using usunblock. Everything works on iplayer in my browser. I tried switching between limelight and auto as well
What if the unblock-us settings are directly in the router and not in XBMC?
Thats how mine are, but it doesnt seem to work, for whatever reason.
Same errors for me. Live TV not working.
Works fine on the website on laptop as well as the tablet apps connected to the same router.
