Full Version: [RELEASE] iPlayer - BBC Video and Music Plugin (UK only!)
Please fix this plugin so trakt scrobbling works (now supports streaming). http://trakt.tv/downloads/xbmc
I've jailbroken my ATV2 and loaded the XBMC and iplayer.zip (v2.4.17). Radio works fine, but error message on all live and recorded TV: "script failed: plugin.video.iplayer". I am not in UK and am able to watch iplayer through VPN on iMac (OSX). Please advise, though the less assumptions made on technical knowledge the better!
(2012-08-05, 02:06)Kieron Wrote: [ -> ]Please fix this plugin so trakt scrobbling works (now supports streaming). http://trakt.tv/downloads/xbmc
don't have any free time right now, but feel free to post a patch on the dev site.
Not seeing the meta information (program data or thumbnails) anymore - anyone else having the same issue? (11.0 and v2.4.17)
(2012-08-10, 23:28)jewelie Wrote: [ -> ]Not seeing the meta information (program data or thumbnails) anymore - anyone else having the same issue? (11.0 and v2.4.17)
Well this has got interesting! I only get this problem if I access iPlayer from a video home screen shortcut on Confluence. Used as home screen video shortcut from Confluence, it is displayed as a "Music - Library" rather than "Video." This appears to stop it displaying thumbnails etc (at least on one box - on another box it still displays them even though it still things it's a Music Library.) I've deleted the iPlayer UserData and it still happens. If I access it via Video->Addons or from Favourites it's fine, it only happens when used as a Confluence home screen shortcut (and it gets displayed as "Music - Library.")
Is this an iPlayer bug, Eden bug, or a Confluence skin bug? Smile
Julie
x
Doh. Ignore me. The one that worked was displaying the list as "Music - Files", the other one was displaying it as "Music - Library" - it was having Library mode on that upset it, turning it off fixed it. Having said that - surely it should be displayed only as "Video" if it's a Video shortcut anyway?
(2012-08-11, 00:43)jewelie Wrote: [ -> ]
Julie
x
Hi, I am suddenly not able to access live tv streams, there seams to be an issue with an array.
I am running the following setup
Starting XBMC (11.0 Git:Unknown), Platform: Linux (Ubuntu 10.04.4 LTS, 2.6.32-40-generic i686). Built on Mar 24 2012
and the error is........
player2.py: INFO (None, None, '0', None, None, None, None, 'bbc_one_london', None, None)
08:27:16 T:2879388528 NOTICE: .
08:27:16 T:2879388528 NOTICE: iplayer2.py: INFO Video stream prefs 0 - h264 3200
08:27:16 T:2879388528 NOTICE: iplayer2.py: INFO getting media information from http://www.bbc.co.uk/mediaselector/4/mti...high_live/
08:27:17 T:2879388528 NOTICE: iplayer2.py: INFO URL Fetch took 0.29 sec for http://www.bbc.co.uk/mediaselector/4/mti...high_live/
08:27:17 T:2879388528 NOTICE: .
08:27:17 T:2879388528 NOTICE: Traceback (most recent call last):
08:27:17 T:2879388528 NOTICE: File "/home/xbmc/.xbmc/addons/plugin.video.iplayer/default.py", line 1086, in <module>
08:27:17 T:2879388528 NOTICE: live_tv.play_stream(label, bitrate, showDialog)
08:27:17 T:2879388528 NOTICE: File "/home/xbmc/.xbmc/addons/plugin.video.iplayer/lib/live_tv.py", line 112, in play_stream
08:27:17 T:2879388528 NOTICE: url = fetch_stream_info(channel, bitrate, provider)
08:27:17 T:2879388528 NOTICE: File "/home/xbmc/.xbmc/addons/plugin.video.iplayer/lib/live_tv.py", line 63, in fetch_stream_info
08:27:17 T:2879388528 NOTICE: media = root.getElementsByTagName( "media" )[0]
08:27:17 T:2879388528 NOTICE: IndexError: list index out of range
08:27:17 T:2879388528 ERROR: Error Type: <type 'exceptions.IndexError'>
08:27:17 T:2879388528 ERROR: Error Contents: list index out of range
08:27:17 T:2879388528 ERROR: Traceback (most recent call last):
I woud appreciate any help that I can get, I rely almost solely on this as my access to the Beeb.
thanks
Paul
(2012-08-11, 08:47)pmbsa Wrote: [ -> ]I woud appreciate any help that I can get, I rely almost solely on this as my access to the Beeb.
thanks
Paul
what version of the plugin? you should post a full debug log (on pastebin or so) and not just the part you think is important. thanks.
Live streams now working with unblockus .... A little too later after the Olympics but I'm not complaining
(2012-07-16, 20:59)epatrickt Wrote: [ -> ]
(2012-07-03, 22:27)epatrickt Wrote: [ -> ]
(2012-07-03, 01:11)buncle Wrote: [ -> ]Does iPlayer work okay if you try from a browser on a computer/laptop on the same network? That would be my first test.
Secondly, if it is only xmbc having problems, try turning on debug logging (from Settings > System > Debugging), trying an iPlayer stream, then examining and/or posting the relevant portion of your xmbc.log file. Hopefully there might be something in there to indicate where the problem lies.
Here is the log file: http://pastebin.com/Qes44Snp
I see some error reports in there but am not sure what they are telling me, or how it can be resolved though! I think line 204 might be a good place to look as it shows, I think, the player trying to run a programme and shows various errors before giving up.
Don't suppose anyone has an idea on my problem please? Live plays but all iplayer streams buffer and then stop. The log is in the pastebin link above. Can't wok it out. Thanks
Love to get a reply from Exobuzz - Nasa TV streams OK. I'm in the UK and iplayer won't go - log already posted. Would be great to get this running - the main reason we installed/jailbroke the ATV2! (Norwegian NRK doesn't work either but I guess that is a blocking issue, unlike iplayer).
Hi Exobuzz,
I have an ATV2 running iOS 4.4.4 and Eden 11 with iPlayer plug in 2.4.17 Here is the log file http://pastebin.com/SjCH0YSk
I cannot launch any video. Either live or recorded.
On my laptop via a web browser, works 100%.
Please advise when you have a moment.
Thank you
Here is how to fix iPlayer in XBMC.
Go ATV Main Screen or on CPU go where DNS address is located.
On Apple TV its Setting/General/ Network
Click done until you see the DNS Address install this.
199.167.030.144
It should work on CPU as well.
There is a new version of the iPlayer. You need to upgrade.
Here ya go http://www.2shared.com/file/gqSjNLFz/iPlayer-v2417.html
Also if you haven't update your lib files. Makes streams work better
(2012-09-18, 01:55)Gainesway1 Wrote: [ -> ]Here is how to fix iPlayer in XBMC.
Hi is this some patched version or same as updated by repo?
it's the newest 1. There are 2 BBC Players. The developer stopped working on other 1. This is the newest 1 available.
I'm pretty sure exobuzz hasn't stopped, he's just busy at the moment.
ATV2, latest firmware and xbmc.
Latest iPlayer plugin, and also getting "script failed: plugin.video.iplayer"
I am in the UK, so no need for any proxy/VPN.
