Full Version: [RELEASE] iPlayer - BBC Video and Music Plugin (UK only!)
Yes I noticed that iplayer seems to be broken under Frodo RC1. Was beginning to think it was just me. Can't access settings either from the Video menu.
Edit: I should add this is on Ubuntu Quantal bare minimum OS with no desktop manager.
Edit: I now have Frodo RC1 running on Ubuntu Precise where the iplayer plugin works perfectly so for me this is likely not an xbmc/iplayer problem.
Edit: As I don't believe this is an iplayer problem I've posted my log on another thread. Have it working through the Music menu but not the Video menu or a thumbnail.
iplayer2 is working perfectly for me. windows xp, frodo rc1 fresh clean install. all settings still on their defaults (except my maximum video quality reduced to 720p).
What ever it was it resolved itself on the second frodo beta, happy bunny now.
It appears to me that the plugin selects the low quality streams for live radio (in direct comparison to the browser stream).
Is there any way to change that behaviour? Switching the codec in the settings did not help.
I can access the settings and browse but the stream crashes fro do rc1, 2 and any nightly build.
Live streams no longer working for me on ATV2 or iPad. Am still on Eden. Anyone know the reason for sudden stop of ability to stream or any advice on a fix? (Was away Dec 17-29 so not sure when change happened.) Thanks
Same problem!! No longer working on ATV2. Stoped streaming about 27th december.
You're not going to get much help without enabling debugging in iPlayer itself and posting the log.
(2013-01-02, 19:14)Hitcher Wrote: [ -> ]You're not going to get much help without enabling debugging in iPlayer itself and posting the log.
It's not working on my OpenElec Raspberry Pi either:
Quote:ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.audio_render omx_err(0x80001000) 12:29:14 T:2685400160
Edit: Further to Smiff's comment below - I am unable to get VOD content (the error above is from an attempt to watch Charlie Brooker's 2012 Wipe on demand).
live streaming broken on xbox also. not a total disaster because TVcatchup can do, but quality was better with iplayer.
normal (nonlive) content seems ok?
edit: confirming onDemand content working perfectly on xbox, tested using 1500k stream from Limelight.
TVcatchup also working well using 1.4.6 from here http://plugins.tvcatchup.com/~xbmc/addon...tvcatchup/
thanks.
live error looks like this
18:00:46 M: 26284032  NOTICE: -->Python Initialized<--
18:01:05 M: 23719936  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
18:01:05 M: 23719936  NOTICE: .
18:01:05 M: 23719936  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: Q:\UserData\plugin_data\video\iplayer\Subtitles
18:01:05 M: 23719936  NOTICE: iplayer2.py: INFO (None, None, '0', 'tv', None, None, None, 'bbc_one_london', None, None)
18:01:05 M: 23719936  NOTICE: iplayer2.py: INFO Video stream prefs 3 - h264 1500
18:01:05 M: 23719936  NOTICE: iplayer2.py: INFO getting media information from http://www.bbc.co.uk/mediaselector/4/mtis/stream/bbc_one_london/pc_stream_audio_video_simulcast_uk_v_lm_p006/limelight
18:01:06 M: 21319680  NOTICE: iplayer2.py: INFO URL Fetch took 1.21 sec for http://www.bbc.co.uk/mediaselector/4/mtis/stream/bbc_one_london/pc_stream_audio_video_simulcast_uk_v_lm_p006/limelight
18:01:06 M: 21319680  NOTICE: .
18:01:07 M: 21176320  NOTICE: DVDPlayer: Opening: rtmp://bbcmedia.fc.llnwd.net:1935/ app=bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc1_inlet_1500&et=1357416007&fmta-token=1953dd844aa48ed30235d16057ac966903426d0bdc9c281b32d515c1dee56fdc tcurl=rtmp://bbcmedia.fc.llnwd.net:1935/bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc1_inlet_1500&et=1357416007&fmta-token=1953dd844aa48ed30235d16057ac966903426d0bdc9c281b32d515c1dee56fdc playpath=s_bbc1_inlet_1500 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=1 live=1
18:01:07 M: 21176320 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:01:07 M: 20652032  NOTICE: Creating InputStream
18:01:37 M: 20135936   ERROR: RTMP_ReadPacket, failed to read RTMP packet header
18:01:37 M: 20135936   ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://bbcmedia.fc.llnwd.net:1935/ app=bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc1_inlet_1500&et=1357416007&fmta-token=1953dd844aa48ed30235d16057ac966903426d0bdc9c281b32d515c1dee56fdc tcurl=rtmp://bbcmedia.fc.llnwd.net:1935/bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc1_inlet_1500&et=1357416007&fmta-token=1953dd844aa48ed30235d16057ac966903426d0bdc9c281b32d515c1dee56fdc playpath=s_bbc1_inlet_1500 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=1 live=1]
18:01:37 M: 20135936  NOTICE: CDVDPlayer::OnExit()
18:01:37 M: 20135936  NOTICE: CDVDPlayer::OnExit() deleting input stream
18:01:37 M: 21471232   ERROR: Playlist Player: skipping unplayable item: 0, path [rtmp://bbcmedia.fc.llnwd.net:1935/ app=bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc1_inlet_1500&et=1357416007&fmta-token=1953dd844aa48ed30235d16057ac966903426d0bdc9c281b32d515c1dee56fdc tcurl=rtmp://bbcmedia.fc.llnwd.net:1935/bbcmedia?as=adobe-hmac-sha256&av=1&te=connect&mp=s_bbc1_inlet_1500&et=1357416007&fmta-token=1953dd844aa48ed30235d16057ac966903426d0bdc9c281b32d515c1dee56fdc playpath=s_bbc1_inlet_1500 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=1 live=1]
18:01:37 M: 21471232  NOTICE: CDVDPlayer::CloseFile()
same thing here, live streaming not working while OD stuff works perfectly...
XBMC Frodo RC3 is installed to Windows 8 64 bit - see notice section in XBMC log extract below. XBMC is working fine, skin is Confluence
I have installed the iPlayer addon via the XBMC repo hitcher following the instructions in this Youtube video
http://www.youtube.com/watch?v=nSjUvNQOLoU
Install went fine but when I select an item to play it shows a progress bar briefly - iplayer 80% - sometimes a brief still shot, and then the player closes and returns me to the item selection menu
I subsequently installed the itvplayer addon and the same thing happens. I have uninstalled and reinstalled both addons to no avail. I have also shutdown the firewall on the XBMC PC. iPlayer from a web browser outside XBMC on the same PC works fine
as does ITV Player. The iPlayer addon settings are at default, although I did try both rtmp port 1935 and port 80 settings - again with no luck. Finally I ran XBMC as Administrator, but the results were the same.
All the error lines from the debug log are included below. I am unsure if the deprecation messages are significant?
ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.iplayer/?pid=b01n9wkh] would seem to be the heart of the matter, but I need an expert to help me work around the smoke and mirrors...
Happy to provide any other material or test results.
the entire XBMC log file is here - http://pastebin.com/DjpRwchC
Anything members could do to point me in the right direction would be great
6:24:47 T:1760 NOTICE: -----------------------------------------------------------------------
16:24:47 T:1760 NOTICE: Starting XBMC (12.0-RC3 Git:20130102-7a6cb7f), Platform: Windows 8 64-bit, build 9200. Built on Jan 3 2013 (compiler 1600)
16:24:47 T:1760 NOTICE: Intel® Core™ i5-3570K CPU @ 3.40GHz
16:24:47 T:1760 NOTICE: Desktop Resolution: 1920x1080 32Bit at 50Hz
16:24:47 T:1760 NOTICE: Running with restricted rights
16:24:47 T:1760 NOTICE: Aero is enabled
16:24:47 T:1760 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
16:24:47 T:1760 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
16:24:47 T:1760 NOTICE: special://masterprofile/ is mapped to: C:\Users\HTPC\AppData\Roaming\XBMC\userdata
16:24:47 T:1760 NOTICE: special://home/ is mapped to: C:\Users\HTPC\AppData\Roaming\XBMC\
16:24:47 T:1760 NOTICE: special://temp/ is mapped to: C:\Users\HTPC\AppData\Roaming\XBMC\cache
16:24:47 T:1760 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
16:24:47 T:1760 NOTICE: Local hostname: HTPC-TVRoom
16:24:47 T:1760 NOTICE: Log File is located: C:\Users\HTPC\AppData\Roaming\XBMC\xbmc.log
Line 526: 16:24:50 T:4492 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
Line 527: 16:24:50 T:4492 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/pvr/win32/addons.xml.md5>
Line 529: 16:24:50 T:4492 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
Line 530: 16:24:50 T:4492 ERROR: Repository XBMC.org PVR Add-ons returned no add-ons, listing may have failed
Line 534: 16:24:57 T:5216 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
Line 536: 16:24:57 T:5216 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
Line 551: 16:25:00 T:1888 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
Line 553: 16:25:00 T:1888 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
Line 564: 16:25:03 T:1984 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
Line 566: 16:25:03 T:1984 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
Line 585: 16:25:10 T:1036 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
Line 587: 16:25:11 T:1036 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
Line 649: 16:25:11 T:1036 ERROR: NEWADDON Invalid Date Format "2012-12-20T10:55:17Z"
Line 760: 16:25:13 T:1760 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.iplayer/?pid=b01n9wkh]
Line 780: 16:25:13 T:1760 ERROR: Control 50 in window 10025 has been asked to focus, but it can't
Line 781: 16:25:13 T:3532 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
Line 783: 16:25:13 T:3532 ERROR: C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
Line 817: 16:25:36 T:1760 ERROR: XBPyThread:Confusedtop - script C:\Users\HTPC\AppData\Roaming\XBMC\addons\service.libraryautoupdate\default.py didn't stop in 5 seconds - let's kill it
I will look into some of the recent problems with live tv as soon as I get a moment. hopefully this week. I have a lot on in regards to projects etc. cheers.
Many Thanks.
Your time and effort very much appreciated.
Have a great New Year.
Thank you so much!
