2013-03-05, 11:13
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192
2013-03-05, 11:50
Fine here.
Debug log?
Debug log?
2013-03-05, 19:56
Can't play the radio streams. Can only play the BBC One live stream (and that only plays when it wants). I am being rather naughty however in using a SmartDNS service since I am in Ireland. Not too pushed though as long as the on demand stuff works. Thanks exobuzz!
2013-03-06, 19:18
(2013-03-05, 11:13)kelmer Wrote: [ -> ]Is this broken for anyone else? I start a stream and it quits after half a second.
I get the same on my an appletv 2 (not running 5.2) running Frodo. Does the same on ITVPlayer.
This is for ondemand programs.
On Demand works on my RPi BUT I cant get any of the live channels on iplayer to work on the ATV or RPi.
It's not the geo locking as I have smartDNS service that is working on my raspberry Pi, PC's etc.
Full Error Log
Shows an audio unit error but as I'm new to this, means nowt to me
These are the last 2 things I want to get working and then I'm happy - Actually, ondemand working on the ATV and live TV iplayer & ITV player on ATV & RPi would be perfect (currently using Notfilmon)
00:00:38 T:157913088 *NOTICE: *fps: 25.000000, pwidth: 1024, pheight: 576, dwidth: 1024, dheight: 576
00:00:38 T:157913088 *NOTICE: Display resolution DESKTOP : 1280x720 (16)
00:00:38 T:159969280 * ERROR: CCoreAudioUnit::Close: Unable to disconnect AudioUnit. Error = -10860
00:00:38 T:104574976 * ERROR: Previous line repeats 1 times.
00:00:38 T:104574976 *NOTICE: Using GL_TEXTURE_2D
00:00:38 T:104574976 *NOTICE: GL: Using CoreVideoRef RGBA render method
00:00:38 T:104574976 *NOTICE: GL: NPOT texture support detected
00:00:39 T:149454848 *NOTICE: iplayer2.py: INFO subtitles: None * - subtitles_file None
00:00:39 T:149454848 *NOTICE: .
00:00:40 T:104574976 * ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.iplayer/?pid=b01r6kzz&feed_channel=bbc_one]
00:00:40 T:104574976 *NOTICE: CDVDPlayer::CloseFile()
00:00:40 T:104574976 *NOTICE: DVDPlayer: waiting for threads to exit
00:00:40 T:155402240 *NOTICE: CDVDPlayer::OnExit()
00:00:40 T:155402240 *NOTICE: DVDPlayer: closing audio stream
00:00:40 T:155402240 *NOTICE: Closing audio stream
00:00:40 T:155402240 *NOTICE: Waiting for audio thread to exit
00:00:40 T:159969280 *NOTICE: thread end: CDVDPlayerAudio::OnExit()
00:00:40 T:155402240 *NOTICE: Closing audio device
00:00:40 T:155402240 * ERROR: CCoreAudioUnit::Close: Unable to disconnect AudioUnit. Error = -10860
00:00:40 T:155402240 *NOTICE: Deleting audio codec
00:00:40 T:155402240 *NOTICE: DVDPlayer: closing video stream
00:00:40 T:155402240 *NOTICE: Closing video stream
00:00:40 T:155402240 *NOTICE: waiting for video thread to exit
2013-03-07, 18:00
what setting do you have in
settings -> video -> file lists -> default select action.
make sure it's set to play. otherwise you need to post a debug log.
2013-03-11, 15:48
Did you get this working ? It's still doing it on mine. No feedback from the log yet.
2013-03-18, 22:22
I can't see if this has been covered but I have a strange issue where I can see the listings of the new episodes like this screen below.
but when I click on any of them instead of giving me the list of episodes for a series to play it just gives the parent .. link with nothing below.
I've tried uninstalling and reinstalling the player from zip.
Playing the Live channels works fine oddly, just can't get the catchup to gives the episodes to play. (It had been working in the past btw)
Any ideas? (other than reformat the drive with a new XBMCbuntu - I'm using the last stable Eden too)
2013-03-20, 15:12
anyone in the UK who wants to talk about XBMC get in contact with me!
2013-04-04, 13:25
Hello there chaps.
I've been having the same problem with the iplayer addon for a couple of months now. Here's the log:
Any ideas what's going on? It tells me to check my network settings, but iplayer works fine from my browser.
PHP Code:
13:23:55 T:9608 NOTICE: Thread XBPyThread start, auto delete: false
13:23:55 T:9608 NOTICE: -->Python Interpreter Initialized<--
13:23:55 T:9608 ERROR: C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
13:23:55 T:9608 ERROR: C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
from sets import Set
13:23:55 T:9608 NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
13:23:55 T:9608 NOTICE: .
13:23:55 T:9608 NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Russ\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
13:23:55 T:9608 NOTICE: iplayer2.py: INFO (None, 'highlights', None, 'tv', None, None, None, None, None, None, None, None)
13:23:55 T:9608 NOTICE: iplayer2.py: INFO Read RSS: http://feeds.bbc.co.uk/iplayer/highlights/tv
13:23:55 T:9608 NOTICE: iplayer2.py: INFO Feed URL not in cache, requesting...
13:23:55 T:9608 NOTICE: iplayer2.py: INFO URL Fetch took 0.01 sec for http://feeds.bbc.co.uk/iplayer/highlights/tv
13:23:55 T:9608 NOTICE: iplayer2.py: INFO Found 10 entries
13:23:55 T:9776 NOTICE: Thread Background Loader start, auto delete: false
13:23:55 T:8388 NOTICE: Previous line repeats 1 times.
13:23:55 T:8388 ERROR: Texture manager unable to load file: C:\Users\Russ\AppData\Roaming\XBMC\addons\skin.neon\media\dialogs\movies\
13:24:00 T:9688 ERROR: Previous line repeats 4 times.
13:24:00 T:9688 NOTICE: Thread XBPyThread start, auto delete: false
13:24:00 T:9688 NOTICE: -->Python Interpreter Initialized<--
13:24:00 T:9688 ERROR: C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
13:24:00 T:9688 ERROR: C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
13:24:00 T:9688 NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
13:24:00 T:9688 NOTICE: .
13:24:00 T:9688 NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Russ\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
13:24:00 T:9688 NOTICE: iplayer2.py: INFO (None, None, 'b01rs2n1', None, None, None, None, None, None, None, None, None)
13:24:00 T:9688 NOTICE: iplayer2.py: INFO Read playlist for b01rs2n1...
13:24:01 T:9688 NOTICE: iplayer2.py: INFO URL Fetch took 0.21 sec for http://www.bbc.co.uk/iplayer/playlist/b01rs2n1
13:24:01 T:9688 NOTICE: .
13:24:01 T:9688 NOTICE: iplayer2.py: INFO Found programme: Parks and Recreation: Series 2: Beauty Pageant
13:24:01 T:9688 NOTICE: iplayer2.py: INFO Found item: ident, None
13:24:01 T:9688 NOTICE: iplayer2.py: INFO Found item: programme, b01rs2mz
13:24:01 T:9688 NOTICE: iplayer2.py: INFO watching channel=None pid=b01rs2n1
13:24:01 T:9688 NOTICE: iplayer2.py: INFO thumb =http://www.bbc.co.uk/iplayer/images/episode/b01rs2n1_512_288.jpg summary=Comedy series set in the parks department of an Indiana town. Leslie judges a beauty contest, but disagrees with the other judges on what makes 'the ideal woman'.
13:24:01 T:9688 NOTICE: iplayer2.py: INFO Reusing existing thumbfile =C:\Users\Russ\AppData\Roaming\XBMC\userdata\Thumbnails\Video\2\28a0ca98.tbn for url plugin://plugin.video.iplayer/?pid=b01rs2n1
13:24:01 T:9688 NOTICE: iplayer2.py: INFO URL Fetch took 0.21 sec for http://www.bbc.co.uk/iplayer/images/episode/b01rs2n1_512_288.jpg
13:24:01 T:9688 NOTICE: iplayer2.py: INFO Video stream prefs 1 - h264 480
13:24:01 T:9688 NOTICE: iplayer2.py: INFO Stream XML URL: http://open.live.bbc.co.uk/mediaselector/4/mtis/stream/b01rs2mz
13:24:01 T:9688 NOTICE: iplayer2.py: INFO URL Fetch took 0.38 sec for http://open.live.bbc.co.uk/mediaselector/4/mtis/stream/b01rs2mz
13:24:03 T:9688 NOTICE: Traceback (most recent call last):
13:24:03 T:9688 NOTICE: File "C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\default.py", line 1081, in <module>
13:24:03 T:9688 NOTICE: watch(feed, pid, showDialog)
13:24:03 T:9688 NOTICE: File "C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\default.py", line 884, in watch
13:24:03 T:9688 NOTICE: (media, pref) = get_matching_stream(item, pref, streams)
13:24:03 T:9688 NOTICE: File "C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\default.py", line 791, in get_matching_stream
13:24:03 T:9688 NOTICE: media = item.get_media_for(pref)
13:24:03 T:9688 NOTICE: File "C:\Users\Russ\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py", line 496, in get_media_for
13:24:03 T:9688 NOTICE: medias = [m for m in self.media if m.application == application]
13:24:03 T:9688 NOTICE: TypeError: 'NoneType' object is not iterable
13:24:03 T:9688 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'NoneType' object is not iterable
2013-04-09, 18:43
I'm unable to get any of the live HD streams to work, it always shows the 688x300 version. I have manually set the desired quality to maximum. I'm using the latest plugin version from SVN (tried 2.4.17 too but didn't work there either). What could be the problem?
2013-04-12, 11:37
I've started having a problem with V17 on my raspberry Pi.. when I try to play something it tells me I'm already streaming and I need to stop that first (not exact wording) and it says to press X
I've rebooted, reinstalled and nothing is working
Rolled back to V15 and this one works (but HD streams don't work .. always plays SD - even from HD channel)
So, can anyone tell me if this is happening with them?
Also, in the meantime is there a way to get V15 to stream HD content?)
Cheers
Cheers
2013-04-15, 15:32
V17 has stopped working for me on both my ATV2 and my RPi (My ITV Player also come up with a script error now)
I haven't had time to roll back or anything yet but anyone know if there is a fix ?
2013-04-16, 20:50
(2013-03-07, 18:00)exobuzz Wrote: [ -> ](2013-03-05, 11:13)kelmer Wrote: [ -> ]Is this broken for anyone else? I start a stream and it quits after half a second.
This fixed it for me, thanks!!
2013-04-18, 15:08
Is there a way to record Iplayer the same as 4od and demand5
2013-04-21, 23:45
When I watch a program via iPlayer, ITVplayer etc I get the progress bar which goes to 80% and the program starts OK. However, with longer programs (over 30 mins or so) it does not get to the end. It goes for a while and then exits back to the menu. If I then go back in and use the number buttons on the remote to go directly to, say, 40 mins into the program it will complete OK. Does anyone have any ideas on what could cause this?
