Full Version: [RELEASE] iPlayer - BBC Video and Music Plugin (UK only!)
Greetings all.
I'm having live streaming issues. On demand works fine, but streaming sometimes works on BBC one, but nothing else.
Debug logs is here : http://xbmclogs.com/show.php?id=16279
I've played with different streams and doens't really help. Any help would be appreciated.
Doesn't seem to be working at all for me last few days.
Failed to fetch URL errors on all programmes.
Android Frodo v12.0
might be doing something wrong as not used to this Android box!
edit: solved, deleting http cache folder fixed this, also internal memory was full.
@ anyone else with android xbmc, do you find you cannot seek in iplayer (and a few other plugins, but not all)? image is totally corrupted and unwatchable after seeking/skipping, plays fine otherwise, but basically unusable because of this. maybe related to amlogic hardware acceleration, not sure, can't get any response over there. i should check that by installing the mainline build shouldn't i.
Have the BBC stopped providing HD versions of catchup ? seems there are very few HD in the HD section of XBMC iPlayer.
(2013-04-16, 20:50)ThePhilMachine Wrote: [ -> ]
(2013-03-07, 18:00)exobuzz Wrote: [ -> ]
(2013-03-05, 11:13)kelmer Wrote: [ -> ]Is this broken for anyone else? I start a stream and it quits after half a second.
what setting do you have in
settings -> video -> file lists -> default select action.
make sure it's set to play. otherwise you need to post a debug log.
This fixed it for me, thanks!!
Is there a technical reason why the default action has to be play, rather than view information? Are there any plans to make it so that the default action doesn't matter? I ask as I reeeeaally like having the default action to be to show more information (don't know why, I just do) Smile
For some reason the bbc6 livestream is crashing my xbmc, and before anyone starts ranting I know I shud submit a debug log :-) but I just wonted to check if anyoneelse had the same problem....
The same here, dafaulting to play is a no go.
The kids and the wife dont like it.
(2013-05-11, 14:56)Birdincamera Wrote: [ -> ]Have the BBC stopped providing HD versions of catchup ? seems there are very few HD in the HD section of XBMC iPlayer.
The HD 'section' was just showing programmes on BBC HD. This closed a few weeks ago to be replaced by a HD variant of BBC 2. But many programmes which are able to be viewed in HD through the normal iPlayer on PCs are not viewable through the XBMC version, unless I'm doing something wrong.
(2013-02-20, 20:55)astranet Wrote: [ -> ]iplayer on demand works well on my RaspbMC - but the live BBC channels (Watch Live) are unreliable. BBC2 seems to be the most unreliable. Tested mainly with the akamai stream. Using xbmc-iplayerv2
I have no problems with the live streams using XBMC iplayer on Windows 7.
This morning BBC1, BBC News and CBBC channels streamed successfully on the first attempt. BBC2 attempted to access the stream and then stopped and returned to the channel list.
On the second attempt the BBC2 video appeared for a few seconds - but no sound, then RaspbMC rebooted. The same on the next attempt at 8:52. The XBMC.old.log for the 8:52 attempt is at:
http://www.xbmclogs.com/show.php?id=1046
I noticed a few others have reported a similar problem - but have found no discussion of the cause. Is this a particular problem with Raspberry Pi?
Using Linux 3.6.11 #1 PREEMPT Sun Feb 3 arm 61
XBMC Git:unknown RaspbMC version 1.
Have had same problems with OpenElec.
I assume that the reason for the problem is understood. Is there a fix or is a future fix likely for Raspberry Pi? Or is there a problem with my setup?
Thanks for any advice.
I have the same issue, I can't watch BBC2 live stream where the other channels are working fine.
Using Linux 3.6.11 #2 PREEMPT Wed Mar 13
XBMC 12.2 Git:20130502-32b1a5e
Is there any workaround/fix yet?
(2013-05-22, 10:52)SPITT Wrote: [ -> ]The same here, dafaulting to play is a no go.
I've actually decided to stick with defaulting to 'show information' (my personal preference), but am just using the 'play using' option from the context menu when playing iplayer videos. Seems better to use a workaround for the one addon that has this issue rather than spoil my experience for the rest of the library. Using the context menu for iplayer isn't too much of a hassle. I do really hope this issue gets addressed at some point however.
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for update dialog
22:07:14 T:3972  NOTICE: .
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for create listitem
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem setinfo
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmc.PlayList
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for logging.info
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setproperty x 3
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setIconImage(thumbfile)
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setThumbnailImage(thumbfile)
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for play.clear()
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.01 sec for play.add
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmc.Player()
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.35 sec for player.play
22:07:14 T:3972  NOTICE: iplayer2.py: INFO Took 0.02 sec for pDialog.close()
22:07:14 T:3260  NOTICE: 1Channel: Playback Stopped
22:07:14 T:3260  NOTICE: 1Channel: Service: Resetting...
22:07:18 T:1384   ERROR: Texture manager unable to load file: special://skin/backgrounds/default.jpg
22:07:19 T:3412   ERROR: Previous line repeats 1 times.
22:07:19 T:3412  NOTICE: Thread XBPyThread start, auto delete: false
22:07:19 T:3412  NOTICE: -->Python Interpreter Initialized<--
22:07:19 T:3412   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
                                              import md5
22:07:19 T:3412   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
                                              from sets import Set
22:07:19 T:3412  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
22:07:19 T:3412  NOTICE: .
22:07:19 T:3412  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Chris\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
22:07:19 T:3412  NOTICE: iplayer2.py: INFO (None, None, None, 'tv', None, None, None, None, None, None)
22:07:19 T:1808  NOTICE: Thread Background Loader start, auto delete: false
22:07:25 T:1976  NOTICE: Thread XBPyThread start, auto delete: false
22:07:25 T:1976  NOTICE: -->Python Interpreter Initialized<--
22:07:25 T:1976   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
                                              import md5
22:07:25 T:1976   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
22:07:25 T:1976  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
22:07:25 T:1976  NOTICE: .
22:07:25 T:1976  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Chris\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
22:07:25 T:1976  NOTICE: iplayer2.py: INFO (<iplayer2.feed object at 0x165CA950>, 'list', None, None, None, None, None, None, None, None)
22:07:25 T:1976  NOTICE: iplayer2.py: INFO Read RSS: http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:25 T:1976  NOTICE: iplayer2.py: INFO Feed URL not in cache, requesting...
22:07:25 T:1976  NOTICE: iplayer2.py: INFO URL Fetch took 0.03 sec for http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:25 T:1976  NOTICE: iplayer2.py: INFO Found 216 entries
22:07:25 T:3272  NOTICE: Thread Background Loader start, auto delete: false
22:07:25 T:1384  NOTICE: Previous line repeats 1 times.
22:07:25 T:1384   ERROR: Texture manager unable to load file: special://skin/backgrounds/default.jpg
22:07:26 T:2136  NOTICE: Thread Jobworker start, auto delete: true
22:07:27 T:3372  NOTICE: Previous line repeats 1 times.
22:07:27 T:3372  NOTICE: Thread XBPyThread start, auto delete: false
22:07:27 T:3372  NOTICE: -->Python Interpreter Initialized<--
22:07:28 T:3372   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
                                              import md5
22:07:28 T:3372   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
22:07:28 T:3372  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
22:07:28 T:3372  NOTICE: .
22:07:28 T:3372  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Chris\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
22:07:28 T:3372  NOTICE: iplayer2.py: INFO (<iplayer2.feed object at 0x0B7CCE90>, 'list', None, None, None, 'Bargain Hunt', None, None, None, None)
22:07:28 T:3372  NOTICE: iplayer2.py: INFO Read RSS: http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:28 T:3372  NOTICE: iplayer2.py: INFO Feed URL not in cache, requesting...
22:07:28 T:3372  NOTICE: iplayer2.py: INFO URL Fetch took 0.03 sec for http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:28 T:3372  NOTICE: iplayer2.py: INFO Found 216 entries
22:07:28 T:2440  NOTICE: Thread Background Loader start, auto delete: false
22:07:28 T:3136   ERROR: Texture manager unable to load file: special://skin/backgrounds/default.jpg
22:07:29 T:3252  NOTICE: Thread XBPyThread start, auto delete: false
22:07:29 T:3252  NOTICE: -->Python Interpreter Initialized<--
22:07:30 T:3252   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
                                              import md5
22:07:30 T:3252   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
22:07:30 T:3252  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
22:07:30 T:3252  NOTICE: .
22:07:30 T:3252  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Chris\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
22:07:30 T:3252  NOTICE: iplayer2.py: INFO (<iplayer2.feed object at 0x0B770470>, None, 'b01qbhk4', None, None, None, None, None, None, None)
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Read playlist for b01qbhk4...
22:07:30 T:3252  NOTICE: iplayer2.py: INFO URL Fetch took 0.17 sec for http://www.bbc.co.uk/iplayer/playlist/b01qbhk4
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Found programme: Bargain Hunt: Series 21: Rockingham 19
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Found item: ident, None
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Found item: programme, b01qbhk0
22:07:30 T:3252  NOTICE: iplayer2.py: INFO watching channel=BBC One pid=b01qbhk4
22:07:30 T:3252  NOTICE: iplayer2.py: INFO thumb =http://www.bbc.co.uk/iplayer/images/episode/b01qbhk4_512_288.jpg   summary=Antiques challenge. Experts Philip Serrell and Paul Laidlaw each have two teams on their hands as they visit Rockingham Castle in Leicestershire to hunt for bargains.
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Reusing existing thumbfile =C:\Users\Chris\AppData\Roaming\XBMC\userdata\Thumbnails\Video\4\4c59e58c.tbn for url plugin://plugin.video.iplayer/?pid=b01qbhk4&feed_channel=bbc_one
22:07:30 T:3252  NOTICE: iplayer2.py: INFO URL Fetch took 0.13 sec for http://www.bbc.co.uk/iplayer/images/episode/b01qbhk4_512_288.jpg
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Video stream prefs 0 - h264 2800
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Stream XML URL: http://www.bbc.co.uk/mediaselector/4/mtis/stream/b01qbhk0
22:07:30 T:3252  NOTICE: iplayer2.py: INFO URL Fetch took 0.38 sec for http://www.bbc.co.uk/mediaselector/4/mtis/stream/b01qbhk0
22:07:30 T:3252  NOTICE: iplayer2.py: INFO protocol: http - kind: http - type: application/ttaf+xml - encoding: None, - bitrate: None
22:07:30 T:3252  NOTICE: iplayer2.py: INFO conn href: http://www.bbc.co.uk/iplayer/subtitles/ng/k/0/b01qbhk0_1369937349.xml
22:07:30 T:3252  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 396
22:07:30 T:3252  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:30 T:3252  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 796
22:07:30 T:3252  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:30 T:3252  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 1500
22:07:30 T:3252  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:30 T:3252  NOTICE: iplayer2.py: INFO protocol: http - kind: sis - type: video/mp4 - encoding: h264, - bitrate: 276
22:07:30 T:3252  NOTICE: iplayer2.py: INFO conn href: http://3gp-acl.bbc.co.uk/sdpgen/3gpclip/iPlayer/prod_3gp_mpeg4_med/wifi_Bargain_Hunt_Series_21_20_01_2013_b01qbhk0_1369933580.mp4
22:07:30 T:3252  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 480
22:07:30 T:3252  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Stream h264 2800 not available, falling back to h264 1500 stream
22:07:30 T:3252  NOTICE: iplayer2.py: INFO watching url=rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:30 T:3252   ERROR: NEWADDON Invalid Date Format "2013-05-14T11:45:40Z"
22:07:30 T:3252  NOTICE: iplayer2.py: INFO Playing preference h264 1500
22:07:30 T:1424  NOTICE: DVDPlayer: Opening: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:30 T:1424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:07:30 T:2632  NOTICE: Thread CDVDPlayer start, auto delete: false
22:07:30 T:2632  NOTICE: Creating InputStream
22:07:31 T:2632   ERROR: RTMP_ReadPacket, failed to read RTMP packet header
22:07:31 T:2632   ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180]
22:07:31 T:2632  NOTICE: CDVDPlayer::OnExit()
22:07:31 T:2632  NOTICE: CDVDPlayer::OnExit() deleting input stream
22:07:31 T:1424   ERROR: Playlist Player: skipping unplayable item: 0, path [rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/400kbps/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/800kbps/MP/b01qbhk0_1369933569.mp4,iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4,iplayerstream/secure_auth/480kbps/MP/b01qbhk0_1369933579.mp4&et=1370473655&fmta-token=8ab7cf6ddc29eca9e3dadbe545f3ab0230b4910c323f68e1b4209859b339c9cd playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01qbhk0_1369933299.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180]
22:07:31 T:3252  NOTICE: iplayer2.py: INFO subtitles: None   - subtitles_file None
22:07:31 T:3252  NOTICE: .
22:07:31 T:3260  NOTICE: 1Channel: Playback Stopped
22:07:31 T:3260  NOTICE: 1Channel: Service: Resetting...
22:07:31 T:1424  NOTICE: CDVDPlayer::CloseFile()
22:07:31 T:1424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:07:31 T:1424  NOTICE: DVDPlayer: waiting for threads to exit
22:07:31 T:1424  NOTICE: DVDPlayer: finished waiting
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for start
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmcgui.DialogProgress()
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for pDialog.create
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.17 sec for get_item
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for setup variables
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for logging
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for get_setting_subtitles
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for update dialog
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.13 sec for update dialog
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for get_setting_videostream
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.39 sec for media 2
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for media.url
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for create listitem
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem setinfo
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmc.PlayList
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for logging.info
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setproperty x 3
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setIconImage(thumbfile)
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setThumbnailImage(thumbfile)
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for play.clear()
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.01 sec for play.add
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmc.Player()
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.43 sec for player.play
22:07:31 T:3252  NOTICE: iplayer2.py: INFO Took 0.73 sec for pDialog.close()
22:07:34 T:3136   ERROR: Texture manager unable to load file: special://skin/backgrounds/default.jpg
22:07:34 T:3480  NOTICE: Thread XBPyThread start, auto delete: false
22:07:34 T:3480  NOTICE: -->Python Interpreter Initialized<--
22:07:34 T:3480   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
                                              import md5
22:07:34 T:3480   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
22:07:34 T:3480  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
22:07:34 T:3480  NOTICE: .
22:07:34 T:3480  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Chris\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
22:07:34 T:3480  NOTICE: iplayer2.py: INFO (<iplayer2.feed object at 0x0B9354D0>, 'list', None, None, None, None, None, None, None, None)
22:07:34 T:3480  NOTICE: iplayer2.py: INFO Read RSS: http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:34 T:3480  NOTICE: iplayer2.py: INFO Feed URL not in cache, requesting...
22:07:35 T:3480  NOTICE: iplayer2.py: INFO URL Fetch took 0.03 sec for http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:35 T:3480  NOTICE: .
22:07:35 T:3480  NOTICE: iplayer2.py: INFO Found 216 entries
22:07:35 T:1784  NOTICE: Thread Background Loader start, auto delete: false
22:07:36 T:3136  NOTICE: Previous line repeats 1 times.
22:07:36 T:3136   ERROR: Texture manager unable to load file: special://skin/backgrounds/default.jpg
22:07:37 T:3908  NOTICE: Thread XBPyThread start, auto delete: false
22:07:37 T:3908  NOTICE: -->Python Interpreter Initialized<--
22:07:37 T:3908   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
                                              import md5
22:07:37 T:3908   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
22:07:37 T:3908  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
22:07:37 T:3908  NOTICE: .
22:07:37 T:3908  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Chris\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
22:07:37 T:3908  NOTICE: iplayer2.py: INFO (<iplayer2.feed object at 0x0B76F230>, 'list', None, None, None, 'imagine...', None, None, None, None)
22:07:37 T:3908  NOTICE: iplayer2.py: INFO Read RSS: http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:37 T:3908  NOTICE: iplayer2.py: INFO Feed URL not in cache, requesting...
22:07:37 T:3908  NOTICE: iplayer2.py: INFO URL Fetch took 0.03 sec for http://feeds.bbc.co.uk/iplayer/bbc_one/list
22:07:37 T:3908  NOTICE: iplayer2.py: INFO Found 216 entries
22:07:37 T:3932  NOTICE: Thread Background Loader start, auto delete: false
22:07:37 T:3136   ERROR: Texture manager unable to load file: special://skin/backgrounds/default.jpg
22:07:39 T:3508  NOTICE: Thread XBPyThread start, auto delete: false
22:07:39 T:3508  NOTICE: -->Python Interpreter Initialized<--
22:07:39 T:3508   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
                                              import md5
22:07:39 T:3508   ERROR: C:\Users\Chris\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
22:07:39 T:3508  NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.17
22:07:39 T:3508  NOTICE: .
22:07:39 T:3508  NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\Chris\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
22:07:39 T:3508  NOTICE: iplayer2.py: INFO (<iplayer2.feed object at 0x0BB13210>, None, 'b01rlx6r', None, None, None, None, None, None, None)
22:07:39 T:3508  NOTICE: iplayer2.py: INFO Read playlist for b01rlx6r...
22:07:39 T:3508  NOTICE: iplayer2.py: INFO URL Fetch took 0.23 sec for http://www.bbc.co.uk/iplayer/playlist/b01rlx6r
22:07:39 T:3508  NOTICE: iplayer2.py: INFO Found programme: imagine...: BeyoncĂ©: Life is But a Dream
22:07:39 T:3508  NOTICE: iplayer2.py: INFO Found item: ident, None
22:07:39 T:3508  NOTICE: iplayer2.py: INFO Found item: programme, b01rlx6h
22:07:39 T:3508  NOTICE: iplayer2.py: INFO watching channel=BBC One pid=b01rlx6r
22:07:39 T:3508  NOTICE: iplayer2.py: INFO thumb =http://www.bbc.co.uk/iplayer/images/episode/b01rlx6r_512_288.jpg   summary=Documentary, directed by and starring BeyoncĂ© Knowles, giving an insight into the life of the 16-time Grammy Award-winning singer, songwriter, actress, wife and mother.
22:07:39 T:3508  NOTICE: iplayer2.py: INFO Reusing existing thumbfile =C:\Users\Chris\AppData\Roaming\XBMC\userdata\Thumbnails\Video\3\38d530f5.tbn for url plugin://plugin.video.iplayer/?pid=b01rlx6r&feed_channel=bbc_one
22:07:39 T:3508  NOTICE: iplayer2.py: INFO URL Fetch took 0.13 sec for http://www.bbc.co.uk/iplayer/images/episode/b01rlx6r_512_288.jpg
22:07:39 T:3508  NOTICE: iplayer2.py: INFO Video stream prefs 0 - h264 2800
22:07:39 T:3508  NOTICE: iplayer2.py: INFO Stream XML URL: http://www.bbc.co.uk/mediaselector/4/mtis/stream/b01rlx6h
22:07:40 T:3508  NOTICE: iplayer2.py: INFO URL Fetch took 0.33 sec for http://www.bbc.co.uk/mediaselector/4/mtis/stream/b01rlx6h
22:07:40 T:3508  NOTICE: .
22:07:40 T:3508  NOTICE: iplayer2.py: INFO protocol: http - kind: sis - type: video/mp4 - encoding: h264, - bitrate: 276
22:07:40 T:3508  NOTICE: iplayer2.py: INFO conn href: http://3gp-acl.bbc.co.uk/sdpgen/3gpclip/iPlayer/prod_3gp_mpeg4_med/wifi_imagine_28_03_2013_b01rlx6h_1370162152.mp4
22:07:40 T:3508  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 796
22:07:40 T:3508  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:40 T:3508  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 1500
22:07:40 T:3508  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:40 T:3508  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 396
22:07:40 T:3508  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:40 T:3508  NOTICE: iplayer2.py: INFO protocol: http - kind: http - type: application/ttaf+xml - encoding: None, - bitrate: None
22:07:40 T:3508  NOTICE: iplayer2.py: INFO conn href: http://www.bbc.co.uk/iplayer/subtitles/ng/6/h/b01rlx6h_1369851840.xml
22:07:40 T:3508  NOTICE: iplayer2.py: INFO protocol: rtmp - kind: limelight - type: video/mp4 - encoding: h264, - bitrate: 480
22:07:40 T:3508  NOTICE: iplayer2.py: INFO conn href: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:40 T:3508  NOTICE: iplayer2.py: INFO Stream h264 2800 not available, falling back to h264 1500 stream
22:07:40 T:3508  NOTICE: iplayer2.py: INFO watching url=rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:40 T:3508   ERROR: NEWADDON Invalid Date Format "2013-03-26T15:38:08Z"
22:07:40 T:3508  NOTICE: iplayer2.py: INFO Playing preference h264 1500
22:07:40 T:1424  NOTICE: DVDPlayer: Opening: rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180
22:07:40 T:1424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:07:40 T:860  NOTICE: Thread CDVDPlayer start, auto delete: false
22:07:40 T:860  NOTICE: Creating InputStream
22:07:40 T:860   ERROR: RTMP_ReadPacket, failed to read RTMP packet header
22:07:40 T:860   ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180]
22:07:40 T:860  NOTICE: CDVDPlayer::OnExit()
22:07:40 T:860  NOTICE: CDVDPlayer::OnExit() deleting input stream
22:07:40 T:1424   ERROR: Playlist Player: skipping unplayable item: 0, path [rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 tcurl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4,iplayerstream/secure_auth/400kbps/b01rlx6h_1370162152.mp4,iplayerstream/secure_auth/480kbps/MP/b01rlx6h_1370162152.mp4&et=1370473665&fmta-token=b54446bf57a776da6f423aa15f9747359b1a6e4abf2a5398a3bb295844630646 playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01rlx6h_1370163685.mp4 swfurl=http://www.bbc.co.uk/emp/10player.swf swfvfy=true timeout=180]
22:07:40 T:1424  NOTICE: CDVDPlayer::CloseFile()
22:07:40 T:1424  NOTICE: DVDPlayer: waiting for threads to exit
22:07:40 T:1424  NOTICE: DVDPlayer: finished waiting
22:07:40 T:3260  NOTICE: 1Channel: Playback Stopped
22:07:40 T:3260  NOTICE: 1Channel: Service: Resetting...
22:07:43 T:3508  NOTICE: iplayer2.py: INFO subtitles: None   - subtitles_file None
22:07:43 T:3508  NOTICE: .
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for start
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmcgui.DialogProgress()
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for pDialog.create
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.24 sec for get_item
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for setup variables
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for logging
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for get_setting_subtitles
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for update dialog
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.13 sec for update dialog
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for get_setting_videostream
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.33 sec for media 2
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for media.url
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for create listitem
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem setinfo
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmc.PlayList
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for logging.info
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setproperty x 3
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setIconImage(thumbfile)
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for listitem.setThumbnailImage(thumbfile)
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for play.clear()
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.01 sec for play.add
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.00 sec for xbmc.Player()
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 3.07 sec for player.play
22:07:43 T:3508  NOTICE: iplayer2.py: INFO Took 0.03 sec for pDialog.close()
22:07:44 T:2204  NOTICE: Thread XBPyThread start, auto delete: false
22:07:44 T:2204  NOTICE: -->Python Interpreter Initialized<--
I am getting errors when playing all the highlight shows. I can play most of the live streams.
I am using XBMC Frodo with the ACE skin.
Hope someone can help Smile
HELP !!!!
Yes, I know that this shouldn't work, but it has been perfectly for so long. BBC iPlayer has stopped working here in the US through an anonymous proxy.
BBC really has been a lifeline for us - frankly, access to BBC TV and radio is the only thing that has stopped us leaving this awful country. TV here is just so bad it is unbelievable.
My guess is that the Beeb have finally put some kind of block restrict IP on the RTMP streams. The log shows nothing - the RTMP stream seems to be found perfectly and just never gets a response from the other side.
Please can someone help out !!!!!
D
Easy fix, the swf file on the beeb site changed, go to:
exchange this on line 346
with this and you're good to go
http://www.bbc.co.uk/emp/releases/iplayer/revisions/617463_618125_4/617463_618125_4_emp.swf
At least that made it work on my end again.
THANK YOU, THANK YOU, THANK YOU !!!!!
It works !!!!!
(2013-06-06, 06:48)ursli Wrote: [ -> ]Easy fix, the swf file on the beeb site changed, go to:
Do you know if a fix incorporating this will be done by anyone as an update, or do we have to do it manually?
yes but I am rather busy on other projects. feel free to submit a patch to the bugtracker though Smile
