Full Version: [RELEASE] iPlayer - BBC Video and Music Plugin (UK only!)
Ok thanks, tried that but I'm getting a lot of 'Permission Denied' messages when i run that command...
for example 1 of them:
rm: cannot remove `/home/atv/.xbmc/addons/script.module.elementtree/lib/docs/pythondoc-elementtree.ElementTree.html': Permission denied
I tried changing permissions from within the Filezilla FTP when accessing the directory to all be 777 so that maybe i could overwrite them, but that didn't seem to work either. Any ideas?
Login as the same user that owns the files (that you use to run xbmc). Or use sudo.
Sorted! Thanks for your help :-)
I was struggling to login as the user that owns the files so had to reset the password for root (sudo passwd root).
Thanks working great.
(2014-05-13, 18:15)exobuzz Wrote: [ -> ]v2.5.8 released - https://drive.google.com/file/d/0B_knGio...sp=sharing
Hopefully the subtitle bug is resolved.
Changes:
2.5.8
* subtitle fixes
* resume point improvements - thanks to neil
* regular expression optimisations - thanks to neil
Here is my report:
* Videos play with subtitles (subtitles set as 'download and play')
** Subtitles are almost always out of sync, need to shift them manually. I think this is not new to 2.5.8, but maybe it is fixable
** Pause and resume sets the subtitles even more out of sync, sometimes more than 10 sec shift.
* Videos play without subtitles when subtitles set to 'none' or 'download to file' , if it was downloaded to a file I have no idea in which folder.
* Live TV does not show subtitles, but I almost never watched live so I am not sure there were subtitles there before (just putting this comment because someone complained about it before)
So iPlayer version 2.5.8 does not crash anymore, I would ask if the subtitle sync is something that can be fixed.
Over the weekend the iplayer on my Apple TV is not working, starts to load then i get an error message to check my logs.
This is:
ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.iplayer/lib/iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
Any ideas?
Andrew
@Andrewt: Are you on the latest version v2.5.8 of iplayer?
(2014-05-26, 12:43)MilhouseVH Wrote: [ -> ]@Andrewt: Are you on the latest version v2.5.8 of iplayer?
No, i'm using 2.4.18a, time for an upgrade?
(2014-05-26, 13:23)Andrewt Wrote: [ -> ]
Check my signature for my repo that contains the latest builds.
There was a leftover import md5 line in 2.5.8 I spotted the other day, and a small code error from one of the recent patchsets so here's a minor update
2.5.9
* remove duplicate import md5 line
* true -> True code fix
2.5.9 works better that 2.5.8, but I keep getting 'Can't locate any usable TV streams'
14:17:15 T:5104 NOTICE: -->Python Interpreter Initialized<--
14:17:15 T:5104 NOTICE: plugin.video.iplayer: Using proxy: type 2 rdns: 1 server: 192.168.2.65 port: 9050 user: *** pass: ***
14:17:15 T:5104 NOTICE: plugin.video.iplayer: Version: 2.5.9
14:17:15 T:5104 NOTICE: plugin.video.iplayer: Subtitles dir: C:\Users\IBM_ADMIN\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
14:17:15 T:5104 NOTICE: plugin.video.iplayer: (<iplayer2.feed object at 0x0DEBCC90>, None, 'b00ymwfn', None, None, None, None, None, None, None, None, None, None, None)
14:17:15 T:5104 NOTICE: plugin.video.iplayer: Read playlist for b00ymwfn...
14:17:16 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 1.35 sec for http://www.bbc.co.uk/iplayer/playlist/b00ymwfn
14:17:16 T:5104 NOTICE: plugin.video.iplayer: Found programme: Top Gear: Series 16: Episode 4
14:17:16 T:5104 NOTICE: plugin.video.iplayer: Found item: ident, None
14:17:16 T:5104 NOTICE: plugin.video.iplayer: Found item: programme, b00z7cfx
14:17:16 T:5104 NOTICE: plugin.video.iplayer: watching channel=BBC Two pid=b00ymwfn
14:17:16 T:5104 NOTICE: plugin.video.iplayer: thumb =http://ichef.bbci.co.uk/programmeimages/p01h0965/b00ymwfn_512_288.jpg summary=Motoring show. The team discovers some of the unusual pitfalls to watch out for when picking up a used car bargain. Simon Pegg is the Star in a Reasonably Priced Car.
14:17:16 T:5104 NOTICE: plugin.video.iplayer: Reusing existing thumbfile=C:\Users\IBM_ADMIN\AppData\Roaming\XBMC\userdata\Thumbnails\c\c4d71776.tbn for url plugin://plugin.video.iplayer/?pid=b00ymwfn&feed_channel=bbc_two
14:17:16 T:5104 NOTICE: plugin.video.iplayer: Video stream prefs 0 - h264 1520
14:17:16 T:5104 NOTICE: plugin.video.iplayer: Stream XML URL: http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:18 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 1.57 sec for http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:18 T:5104 NOTICE: plugin.video.iplayer: Stream XML URL: http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:19 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 1.35 sec for http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:19 T:5104 NOTICE: plugin.video.iplayer: Stream XML URL: http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:20 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 1.21 sec for http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:20 T:5104 NOTICE: plugin.video.iplayer: Stream XML URL: http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:21 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 0.90 sec for http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:21 T:5104 NOTICE: plugin.video.iplayer: Stream XML URL: http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:22 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 1.00 sec for http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:22 T:5104 NOTICE: plugin.video.iplayer: Stream XML URL: http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:23 T:1308 NOTICE: Thread FileCache start, auto delete: false
14:17:24 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 1.80 sec for http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:24 T:5104 NOTICE: plugin.video.iplayer: Stream XML URL: http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:25 T:6788 NOTICE: Thread FileCache start, auto delete: false
14:17:25 T:5104 NOTICE: plugin.video.iplayer: URL Fetch took 1.36 sec for http://open.live.bbc.co.uk/mediaselector...m/b00z7cfx
14:17:25 T:5104 NOTICE: plugin.video.iplayer: Available streams by preference: []
Because the BBC service is not returning any, most likely because your IP is not in the UK (or it thinks it isn't). BTW - Please use xbmclogs.com for debug logs (and post full ones).
You can confirm this by opening one of those mediaselector links in a browser from the same ip and checking the contents.
I have tried v2.4.9 as suggested and still no joy. I'm not in the UK (AU) but using Unblock-US and iplayer works on ipad and PC. I got the following errors on my debug list:
http://xbmclogs.com/show.php?id=211729
Any help is gratefully received, but please I need it kept simple!
Andrew
(2014-05-27, 09:31)Andrewt Wrote: [ -> ]Hi,
email unblock-us ?
also: http://support.unblock-us.com/customer/p...ot-working
I cannot offer any support watching the streams outside of the UK. It is also no fault/error of the plugin, so nothing can be done on our side.
edit: after reading your message again do you mean it works ok on XBMC on your pc and ipad?
- to add for whatever reason the rtmp hankshake is failing - so at least your connection to get auth code from the xml is working via proxy - I cant reproduce it on my end, so I can only assume its related to geolocking at the rtmp protocol level, some compatibility issue with your rtmp library and the handshake code/swf hash). So possibly a device specific issue too. If it is device issue, I still can't help, as the plugin just sends urls to xbmc to play (and xbmc sends the parameters to librtmp etc)
I am using TOR to get UK IP. This worked for me a long time. Seems to me that BBC introduced active TOR exit points blacklisting......
