Full Version: [RELEASE] iPlayer - BBC Video and Music Plugin (UK only!)
Just tried the skipping in iplayer on 21979 on an xbox and doesn't seem to work, just the usual 1 second skip. Should it be working ok?
EDIT: ooookk another example of me not paying attention. not doing so well at that lately... merge soon pls Smile
I'm having some issues with the plugin. When I try to watch a program nothing appears to happen.
The log file reports the following...
09:50:34 09:50:39 M: 2322432 NOTICE: DVDPlayer: Opening: rtmp://cp41752.edgefcs.net:1935/ondemand?_fcs_vhost=cp41752.edgefcs.net&auth=dbEczaAcydYd9aEdpaEcxcBbZb6dobTbsdw-bkFO3F-c0-d0i_-GnrFEqwqGBnHswC&aifp=v001&slist=secure/b000m0x91H264124425414
09:50:39 M: 2342912 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
09:50:39 M: 1818624 NOTICE: Creating InputStream
09:50:39 M: 1798144 NOTICE: Creating Demuxer
09:50:40 M: 1740800 NOTICE: Opening video stream: 0 source: 256
09:50:40 M: 1740800 NOTICE: Creating video codec with codec id: 0
09:50:40 M: 1740800 ERROR: Unsupported video codec
09:50:40 M: 1740800 WARNING: CDVDPlayer::OpenVideoStream - Unsupported stream 0. Stream disabled.
09:50:40 M: 1740800 NOTICE: Opening audio stream: 1 source: 256
09:50:40 M: 1740800 NOTICE: Finding audio codec for: 0
09:50:40 M: 606208 ERROR: CThread:ConfusedtaticThread : Access violation at 0x00266c9d: Writing location 0x00000000
09:50:40 M: 606208 NOTICE: CDVDPlayer::OnExit()
09:50:40 M: 606208 NOTICE: DVDPlayer: eof, waiting for queues to empty
09:50:40 M: 606208 NOTICE: CDVDPlayer::OnExit() deleting demuxer
09:50:40 M: 643072 NOTICE: CDVDPlayer::OnExit() deleting input stream
09:50:40 M: 1183744 ERROR: Playlist Player: skipping unplayable item: 0, path [rtmp://cp41752.edgefcs.net:1935/ondemand?_fcs_vhost=cp41752.edgefcs.net&auth=dbEczaAcydYd9aEdpaEcxcBbZb6dobTbsdw-bkFO3F-c0-d0i_-GnrFEqwqGBnHswC&aifp=v001&slist=secure/b000m0x91H264124425414]
09:50:40 M: 872448 NOTICE: CDVDPlayer::CloseFile()
09:50:40 M: 872448 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
09:50:40 M: 872448 NOTICE: DVDPlayer: waiting for threads to exit
09:50:40 M: 872448 NOTICE: DVDPlayer: finished waiting
09:50:40 M: 462848 ERROR: Out of memory loading texture: guide-blade-overlay-edge-right.png (need 1048704 bytes, have 462848 bytes)
09:50:40 M: 462848 ERROR: Texture manager unable to load bundled file: guide-blade-overlay-edge-right.png
I've tried setting my cache to 8mb and 4mb.
My iplayer settings are left to defaults.
My XMBC Details are...
09:48:54 M: 55894016 NOTICE: Starting XBMC, Platform: Xbox. Built on Jun 26 2009 (SVN:21142, compiler 1310)
Any ideas?
I think the trick may be the line with "Out of memory". Try using the PM3.HD skin at 720p or lower as it is quite easy to exhast memory on an xbox. You can also enable debugging to view memory usage.
Cheers
Dink
PGallagher Wrote:09:50:40 M: 462848 ERROR: Out of memory loading texture: guide-blade-overlay-edge-right.png (need 1048704 bytes, have 462848 bytes)
My XBMC Details are...
Any ideas?
dink Wrote:I think the trick may be the line with "Out of memory". Try using the PM3.HD skin at 720p or lower as it is quite easy to exhast memory on an xbox. You can also enable debugging to view memory usage.
Cheers
Dink
You're quite right!
I've actually droppped the MC360 skin down to 720p and that's sorted it! All is well!
:-D
Thanks for your help!
motd2k Wrote:I've added RTMP seek support in r21929. You can now either type a location to skip to using the number buttons on the keyboard or remote, or use skip.
motd
Thanks motd2k. Skipping now works well on my Linux box.
Cheers
Dink
Little youtube video showing my Revo booting and running this plugin Smile
http://www.youtube.com/watch?v=Mu3v5QFBaWE
motd
Hi Folks
I have made a small update which fixes a problem with the BBC HD channel. Recent changes to the media selector xml from the BBC site resulted in an unsupported stream being selected.
The update is available at
http://xbmc-iplayerv2.googlecode.com/fil...-08-17.zip
I will make it available via SVN later today (if no problems are reported)
Cheers
Dink
dink Wrote:Hi Folks
Yay! Thanks!
Nova
@dink: I gave a try to the new skipping support. It's all great except that the plugin does not seem to support the automatic resume or the bookmarking features.
Is that a limitation of the current release of XBMC?
I am using IPlayer 2009-08-17 and XBMC 22252 (PC).
nova77_ Wrote:@dink: I gave a try to the new skipping support. It's all great except that the plugin does not seem to support the automatic resume or the bookmarking features.
Yup that's a current XBMC limitation. Hopefully someone like motd2k who is familiar with the C++ RTMP code can add this at some point.
Cheers
Dink
When I try to load the iplayer plugin on my Xbox, the programme lists all appear correctly but when I try to watch any TV programme I get the following error:
Can't locate tv stream for flashmed
Any ideas please?
p.s. I use Sky for my Broadband.
thanks
Same here with: May 21 2009 (SVN:20439, compiler 1310)
Log here: http://www.pt-1.net/xbmc/xbmc21_08_2009.log
21:44:39 M: 29335552 NOTICE: iplayer2.py: 2009-08-21 21:44:39,131 INFO conn href: rtmp://cp41752.edgefcs.net:1935/ondemand?_fcs_vhost=cp41752.edgefcs.net&auth=dbEbNdZdHcjaDaDdUcfadb9aRbAbnayccbV-bkJWC2-c0-d0i_-KqmGDpFnOBwHtyH&aifp=v001&slist=secure/480kbps/b000m70yth264_flv_lo125263458
21:44:39 M: 29335552 NOTICE: .
21:44:39 M: 29335552 NOTICE: connection kind = akamai not found
I have added your latest Iplayer HD plugin and the audio is out of sync, it appears that my video is slightly slow but the audio is running at the correct speed, so eventually the video is way out of sync.
any ideas.?
I noticed a similar problem yesterday, but it was ok with the HD streams, so I'm guessing that you might find it was down to the BBC not putting all the content up at the same time.
Anybody else getting "Can't locate tv stream forflashmed" ?
(trying to play Cbeebies content..)
