2009-05-19, 15:31
2009-05-19, 16:02
I see you are pretty new to XBMC ,i notice that when you made a plugin for just 1 stream .i want to say there is also another way to make a little selfmade playlist with streams, podcast and rss like you do available to others.That's with navi-X script and plugin.If you make here http://navix.turner3d.net/an account.Than go to my playlist.First you need to create a new playlist and than add a new entry.
Than you others can view your own made customize playlist in Navi-Xtreme.
And it will also much easier for others to view your updates from broken streams.
If you need help ask it preferably here Official Navi-X Media Browser Support Thread or in the shoutbox or forums here http://navix.turner3d.net
2009-05-19, 16:15
2009-05-21, 22:37
tikkiew Wrote:I see you are pretty new to XBMC ,i notice that when you made a plugin for just 1 stream .i want to say there is also another way to make a little selfmade playlist with streams, podcast and rss like you do available to others.That's with navi-X script and plugin.If you make here http://navix.turner3d.net/an account.Than go to my playlist.First you need to create a new playlist and than add a new entry.Please stop pitching Navi-X in all threads! Continuing that trend will eventually get you banned from this forum!
2009-05-21, 23:09
i ain't pitching i am just helping people .
But i thought this forum was intended to do so
And if the answer would be try using Navi-X
Than i can't say this
This sounds weird to me
Why i replied in this case .I will explain.
Laser78 made first a script just for 1 stream.
Than he makes this playlist for just 1 stream.
Which is not a plugin like he says by the way.
Doesn't this sound strange to you
But apparently you didn't read my reply completely.
So you would know this is not a plugin
And this wouldn't be moved to Help and Support > Script/Plugin Help and Support
And nobody helped him except me.
And don't say i do this in all threads.Cause i ain't.
Give me an example,where you find this pitching
and not providing a better solution
better just pm please and give me some examples.
2009-05-22, 00:19
iRoNBiLL has laid the groundwork so it does not take much to set us of when it comes to posting about Navi-X in threads that are not about Navi-X, so the phrase "why not use Navi-X instead" in not very popular due to that, thus all Navi-X dicussion goes in http://forum.xbmc.org/showthread.php?tid=43884 and no where else.
2009-05-22, 02:11
k if you want it like that, i will do what you want.
I will also not reply when i see a problem.
That is not only in in my opinion the easier or better solution but the only solution at the moment on xbmc.
well concerning IronBill i know about the situation.
and he can talk for himself as he probably did in the past.
Also i hope in the future this phrase '' why not use Navi-X instead''
will give less problems to others.And would be more seen as providing some help.
2010-09-25, 18:31
This plugin working with dharma b2? How do i install it?
Thank you
Thank you
2012-01-19, 09:49
is it already working!?
