2009-05-19, 17:47
2009-05-20, 11:05
nobody ?
2009-05-21, 11:26
Player.isPlayingVideo() tells you whether the video is playing (http://xbmc.sourceforge.net/python-docs/...tml#Player), I don't know about the full-screen part.
What do you to use it for?
2009-05-25, 14:18
Yes, I know that.
I have done a small python script, and I would like to differentiate the behaviour when someone click on an icon when the player is a fullscreen or not.
An example would be a button to set the player is fullscreen (but not a toggle)
2009-05-25, 14:25
videoplayer.isfullscreen (info bool)
2009-05-25, 14:41
Hey Spiff,
the method doesn't seem to be in the docs (http://xbmc.sourceforge.net/python-docs/...tml#Player), what does the boolean parameter do?
2009-05-25, 15:08
uhm, it returns true if the video player is in full screen and false if it's not. used for visibility conditions...
it is NOT part of the python player object, as i said it is an info bool.
if there is no python method for grabbing info bools, you need to do it through the http api
2009-05-25, 16:18
Thanks Spiff.
Ok, I got the list of boolean conditions:
http://wiki.xbmc.org/index.php?title=Lis...Conditions
no idea which HTTP API function to use to get them...
http://wiki.xbmc.org/?title=List_of_Built_In_Functions
2009-05-25, 16:40
well, i did not say you had to use the http api. some simple grepping brought
xbmc.getCondVisibility(condition)
ie. xbmc.getCondVisibility('videoplayer.isfullscreen')
voila
voila
2009-05-25, 17:10
Thank spiff, much appreciated!
