I installed XBMC today on an up-to-date Windows XP system and all i get is the "XBMC Media Center has encountered a problem and needs to close." and to send error report to microsoft. Any Ideas?
When run, it goes to a completely black screen then it shrinks to a smaller black screen and displays the error message.
Many potential problems with many potential solutions. A forum search should've been your first move, all of the common problems have been resolved MANY times. If you still have trouble after exhausting the search results, see the sticky about posting your problem in a useful manner and post back with the requested details.
LOL... I was gettin to the sticky note part and the log, but didnt think I would get a response so fast.. Here is the log file:
19:14:56 T:1248 M:261746688 NOTICE: -----------------------------------------------------------------------
19:14:56 T:1248 M:261718016 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on May 5 2009 (SVN:19952, compiler 1500)
19:14:56 T:1248 M:261718016 NOTICE: AMD Athlon XP 2000+
19:14:56 T:1248 M:261718016 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
19:14:56 T:1248 M:261713920 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
19:14:56 T:1248 M:261713920 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\Mike\Application Data\XBMC\userdata
19:14:56 T:1248 M:261713920 NOTICE: special://home/ is mapped to: C:\Documents and Settings\Mike\Application Data\XBMC
19:14:56 T:1248 M:261713920 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\Mike\Application Data\XBMC\cache
19:14:56 T:1248 M:261713920 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
19:14:56 T:1248 M:261713920 NOTICE: Log File is located: C:\Documents and Settings\Mike\Application Data\XBMC\xbmc.log
19:14:56 T:1248 M:261713920 NOTICE: -----------------------------------------------------------------------
19:14:56 T:1248 M:261689344 NOTICE: Setup SDL
19:14:56 T:1248 M:261087232 NOTICE: load settings...
19:14:56 T:1248 M:261079040 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:14:56 T:1248 M:261074944 NOTICE: loading special://masterprofile/guisettings.xml
19:14:57 T:1248 M:260886528 NOTICE: Getting hardware information now...
19:14:57 T:1248 M:260886528 NOTICE: Checking resolution 10
19:14:57 T:1248 M:260886528 NOTICE: Setting autoresolution mode 12
19:14:57 T:1248 M:260870144 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
19:14:57 T:1248 M:260870144 NOTICE: Default DVD Player: dvdplayer
19:14:57 T:1248 M:260870144 NOTICE: Default Video Player: dvdplayer
19:14:57 T:1248 M:260870144 NOTICE: Default Audio Player: paplayer
19:14:57 T:1248 M:260939776 NOTICE: special://masterprofile/sources.xml
19:14:57 T:1248 M:263647232 NOTICE: GL_VENDOR = Microsoft Corporation
19:14:57 T:1248 M:263647232 NOTICE: GL_RENDERER = GDI Generic
19:14:57 T:1248 M:263647232 NOTICE: GL_VERSION = 1.1.0
19:14:57 T:1248 M:263647232 NOTICE: GL_EXTENSIONS = GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
Next time please, enable debugging and use pastebin. You get lucky this time in that YOU ARE THE 1000th USER TO NOT INSTALL PROPER GFX DRIVERS!!! As your prize you win free exclusive rights to the forum search button!!! Enjoy!
