I tried to look through several threads and there is no place that tells where I can download the plugins for Hulu and CBS TV.
Can you point to it please?
Hulu is currently dead and it isn't looking good for a resurrection any time soon. Use this:
http://xbmc-addons.googlecode.com/svn/pa...taller.zip to get the CBS plugin.
Put it into your plugins/programs under Q: and then access it from the programs menu. If programs isn't showing for you, go to Settings > Skin Settings and enable programs.
Hulu is dead in the water for the time being.
You can get many plugins from the SVN Repo installer (program plugin) included with XBMC
joebrady Wrote:Hulu is dead in the water for the time being.
Where do I get the SVN repo installer?
I replied in the plugins and scripts support to your same question:
nicoli_k Wrote:Hulu is currently dead and it isn't looking good for a resurrection any time soon. Use this: http://xbmc-addons.googlecode.com/svn/pa...taller.zip to get the CBS plugin.
Install Playon and add it to the video source list.
Works great. Not free, but it does have a lot to offer .
