Full Version: Help!?!?! Did NKPatcher brick my Xbox?!
Hey all. Im omething of a bewbie to Xbox XBMC, so please be patient.
Recently I modded one of my Xboxes with a softod and installed UnleashX. I then installed the latest Xbox Stable build of XBMC and set it to auto boot directly to XBMC.
I then installed ots of emulators etc and had a ball... until I decided to improve the picture. I am running this Xbox on a 52" HD TV and was previously using an S-Video cable, whiched looked a little ordinary. So I purchased a component cable and plugged it in, only to e greeted with the dreaded pink XBMC (I hear this is common).
I searched and searched for a fix to this problem and the only one I could find dealt with using NKPatcher to patch the kernel. So from XBMC I booted UnleashX, and used the NKPatcher Progressive scanning patch. It worked fine. Then when I rebooted I got a blank screen, didnt even get the sound file that plays when XBMC boots (so I know it is not just a video problem).
No matter what I do now the system simply goes to a black screen. Is NKPatcher some sort of super bricking joke program? Or have I just overlooked something simple.
Any help would be greatly appreciated.
Thanks,
abraXXious
This is a question for xbox-scene.com forums.
