Full Version: "ClearArt" concept - overlay type artwork for ex. 'episode poster/fanart on paused'
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
can you give me an example of a show with a colon
Terminator: The Sarah Conner Chronicles
reaven Wrote:can you give me an example of a show with a colon
http://thetvdb.com/?string=%3A&searchser...ion=Search
i have that show in my library and its fine.
I have the same .xml and my clearArt is name < The Sarah Connor Chronicles.png > and the show folder name is < Terminator The Sarah Connor Chronicles > without colons and dont know how its all working fine.
<control type ="image">
        <description>tv show image</description>
        <posx>1049</posx>
        <posy>-108</posy>
        <width>230</width>
        <height>115</height>
        <texture diffuse="thumbs/movieposter_mask.png">clearArt/$INFO[VideoPlayer.TVShowTitle].jpg</texture>
        <visible>VideoPlayer.Content(episodes)</visible>
    </control>
thats why I was telling you about the case sensitive
because it checks against that and if you see in xbmc it display the show title all in caps and even on the show .nfo its different.
so you have the real name, the .nfo name the folder name and the image name all different and still works, if it was case sensitive it would be a mess to make it work cross-platform in terms of the skin not the application you have only one skin for all platform.
Only aeon shows the title in all caps, and that is due to the font used.
Sorry the title should be capitalized exactly as it is in the nfo to work crossplatform.
On the topic of the colon, I'd be interested to see the nfo file for your Sarah Connor show to check if the title is proper there.
Quote:<?xml version="1.0" encoding="utf-8"?>
<tvshow xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<title>Terminator: The Sarah Connor Chronicles</title>
My filename is
Terminator: The Sarah Connor Chronicles.png
I've just tried The Sarah Connor Chronicles.png and it does NOT work.
  <rating>7.9</rating>
  <season>-1</season>
  <episode>0</episode>
  <displayseason>-1</displayseason>
  <displayepisode>-1</displayepisode>
  <episodeguideurl>http://www.thetvdb.com/api/1D62F2F90030C444/series/80344/all/en.zip</episodeguideurl>
  <plot>The series picks up four years after the events of Terminator 2: Judgment Day with John and Sarah Connor hiding from the government. After two years in one place Sarah decides they need a change of scenery. Cameron Phillips, a reprogrammed Terminator sent to protect John, informs them that Judgment Day was not stopped and will take place in 2011.</plot>
  <thumb />
  <mpaa>TV-14</mpaa>
  <watched />
  <id>tt0851851</id>
  <tvdbid>80344</tvdbid>
  <genre>Action and Adventure/Drama/Science-Fiction</genre>
  <premiered>2008-01-13</premiered>
  <studio>FOX</studio>
am using that on the mac with Aeon skin
How difficult would it be to pull the file from the base directory of each series?
Like I said before this could solve all the problems users of various OSes are facing.
how difficult ?
hummm let me think...
is "impossible" difficult enough ? Big Grin
when the video is launched, we have only access to the VideoPlayer. properties
(ListItem is destroyed) and none of them can give us the path to a folder
That's what I said, about the importance of having xbmc team create a new field in the db, so that they can had a VideoPlayer.clearart wich would store the path to the clearart or something like that...
I guess impossible is a good answer. :p
So the other option aside from waiting for the devs is to parse the title removing spaces and punctuation and the such.
If anybody has requests I'll try and fill them....If you can find me the image, that would help, because some shows I have no clue who the main characters are.
Imaginos is right.
there is no images for tvshow at Playing level, just the episode thumb
I request this a few weeks ago
http://trac.xbmc.org/ticket/6607
is not the same but instead of
VideoPlayer.clearArt
it would be better
VideoPlayer.path
that way you will get more possibilities to do other things not just pull the clearArt.
Just started using these. Wow. You guys are awesome. Well done.
krypt2nite Wrote:Just started using these. Wow. You guys are awesome. Well done.
Thanks a lot !!
great stuff. one question - if the show's name is in hebrew and i change the image to match the hebrew name - it still doesn't show - is there anything that can be done?
thanks a lot
if the name in the .nfo is the same as the clearart filename it suppose to show, whats the name of the show in hebrew and whcih name you have in the tvshow.nfo
