Full Version: "ClearArt" concept - overlay type artwork for ex. 'episode poster/fanart on paused'
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
Sweet! Anyone experiencing the same problem, or want to make their clearart a bit larger. These setings gave me the desired effect...
<control type ="image">
        <description>tv show image</description>
        <posx>901</posx>
        <posy>-205</posy>
        <width>380</width>
        <height>213</height>
        <texture>clearart/$INFO[VideoPlayer.TVShowTitle].png</texture>
        <aspectratio>keep</aspectratio>
        <visible>VideoPlayer.Content(episodes) + !Skin.HasSetting(yesclearart)</visible>
    </control>
reaven Wrote:no, thank you !
lol
I now want to add another rss ticker, to be able to see 2 at the same time its killing waiting to the rss ends so you can see the next one
i'd love that!!!
eQUIV Wrote:Sweet! Anyone experiencing the same problem, or want to make their clearart a bit larger. These setings gave me the desired effect...
        <posx>901</posx>
        <posy>-205</posy>
        <width>380</width>
    </control>
This will only work for people who have the same size display as you, for example, clearArt would appear near the center of my screen if I used that.
Oh ok. Well anyone running XBMC at 1920x1080 and wants slighly larger clearart should use my above settings.
Hmm strange, I'm using that res too so I tested to try and it did appear near the center Confused
For me this works:
        <posx>1049</posx>
        <posy>-170</posy>
        <width>230</width>
        <height>225</height>
    </control>
Weird !
Really? That's bizarre, mine is in the bottom right corner.
eQUIV Wrote:Really? That's bizarre, mine is in the bottom right corner.
but you realize your are the only one with that problem.
reaven Wrote:but you realize your are the only one with that problem.
Problem? It's no problem. It's exactly where it should be. I just wanted my clearart a little larger. After I tweaked the size larger I had to tweak the position as well. It looks great now.
I think DumbGum had different results because his image size is set smaller than mine.
Hi Reaven & community;
Great work on the mod. I downloaded it today, and played around a little with the top-bar. I thought I share the xml just in case anyone likes it (with Reaven's permission)...
TV Show:
Movie:
Replace code from line 73 (<!-- mod top control -->) to line 132 (</control>) in Reaven's DialogSeekBar.xml with the following:
<!-- Top title bar -->
<control type="group">
    <description>top controls</description>
    <control type="image">
        <description>Panel</description>
        <posx>0</posx>
        <posy>-630</posy>
        <height>109</height>
        <width>1280</width>
        <texture>osd/osd_back.png</texture>
                <include>Animation_CommonFade</include>
        <colordiffuse>cdffffff</colordiffuse>
    </control>
    <!--- TVSHow - Episode Title -->
    <control type="label">
        <posy>-590</posy>
        <posx>0</posx>
        <height>30</height>
        <width>1280</width>
        <align>center</align>
        <aligny>center</aligny>
        <font>Font_SettingsSectionTitle</font>
        <label>$INFO[VideoPlayer.TVShowTitle] - $INFO[VideoPlayer.Title]</label>
        <visible>VideoPlayer.Content(episodes)</visible>
    </control>
    <!--- Movie Title -->
        <posy>-590</posy>
        <posx>0</posx>
        <height>30</height>
        <width>1280</width>
        <label>$INFO[VideoPlayer.Title]</label>
        <visible>![VideoPlayer.Content(episodes)]</visible>
    </control>
    <!--- TV Show Season - Episode subtitle -->
        <posy>-560</posy>
        <posx>0</posx>
        <height>30</height>
        <width>1280</width>
        <font>Font_OSDSeek</font>
        <label>Season $INFO[VideoPlayer.Season] - Episode $INFO[VideoPlayer.Episode]</label>
    </control>
    <!--- Movie rating - year - Director subtitle -->
        <posy>-560</posy>
        <posx>0</posx>
        <height>30</height>
        <width>1280</width>
        <label>$INFO[VideoPlayer.Director] $INFO[VideoPlayer.year]</label>
    </control>
    <!--- System time on the left -->
        <posy>-590</posy>
        <posx>30</posx>
        <height>30</height>
        <width>490</width>
        <align>left</align>
        <label>$INFO[System.Time]</label>
    </control>
    <!--- "NOW" label the left -->
        <posy>-560</posy>
        <posx>30</posx>
        <height>30</height>
        <width>490</width>
        <align>left</align>
        <label>NOW</label>
    </control>
    <!--- Ending time on the right -->
        <posy>-590</posy>
        <posx>1250</posx>
        <height>30</height>
        <width>490</width>
        <align>right</align>
        <label>$INFO[Player.FinishTime]</label>
    </control>
    <!--- "END" label the right -->
        <posy>-560</posy>
        <posx>1250</posx>
        <height>30</height>
        <width>490</width>
        <label>END</label>
    </control>
    <!--- codec, resolution and audio on top -->
        <posy>-620</posy>
        <posx>0</posx>
        <height>30</height>
        <width>1280</width>
        <label>Video: $INFO[VideoPlayer.VideoCodec] at $INFO[VideoPlayer.VideoResolution] | Audio: $INFO[VideoPlayer.AudioChannels] Channels $INFO[VideoPlayer.AudioCodec]</label>
    </control>
</control>
Remove the system time and end time on the bottom bar by removing ($INFO[System.Time]) on line 365 and ($INFO[Player.FinishTime]) on line 376.
Alternatively you could leave the time and endtime on the bottom and just delete the following from my code above.
        <posy>-590</posy>
        <posx>30</posx>
        <height>30</height>
        <width>490</width>
        <align>left</align>
    </control>
        <posy>-560</posy>
        <posx>30</posx>
        <height>30</height>
        <width>490</width>
        <align>left</align>
        <label>NOW</label>
    </control>
        <posy>-590</posy>
        <posx>1250</posx>
        <height>30</height>
        <width>490</width>
    </control>
        <posy>-560</posy>
        <posx>1250</posx>
        <height>30</height>
        <width>490</width>
        <label>END</label>
    </control>
This is my very first time posting a modification for XBMC, so please make a backup of the DialogSeekBar.xml file. Nod
Enjoy. Wink
Lukas
Nice work Lukas Smile
In the dialogseekbar.xml, you have :
<label>[b][COLOR ffc1c2c3]Season $INFO[VideoPlayer.Season] | Episode $INFO[VideoPlayer.Episode][/COLOR][/b]</label>
You'd better change to
<label>[b][COLOR ffc1c2c3]$LOCALIZE[31062] $INFO[VideoPlayer.Season] | $LOCALIZE[31063] $INFO[VideoPlayer.Episode][/COLOR][/b]</label>
The same way, concerning the codecs infos on top, let's have it international !
instead of :
try :
<label>Video: $INFO[VideoPlayer.VideoCodec]: $INFO[VideoPlayer.VideoResolution] kbps | Audio: $INFO[VideoPlayer.AudioChannels] $LOCALIZE[31703] $INFO[VideoPlayer.AudioCodec]</label>
thanks Imaginos !
Finished making the new osd for my mod today and was experimenting with clearArt, if the clearArt is of full bodies (i.e: with legs) you can use the osd as a proper platform for the characters in the art to stand on lol. Like this :
Its kinda cool I thought, but probably wouldn't work with a lot of the art. In any case I think I'll package clearArt with the new revision of my mod if thats alright with you Reaven.
DuMbGuM Wrote:Nice work Lukas Smile
Thnx man, big compliment coming from you... PitchBlack is beautiful.
Cheers !! The update for it will be available hopefully before Friday if all goes well. Wink
