2009-07-31, 02:06
so they show up randomly, it can be difficult as you said its just change the control, from image to multiimage. the only problem would be to create a folder for each show or create a clearArt folder in each show.
reaven Wrote:if you use the multiimage control the files names doesn't matter because the control will load up every and any image in the folder specify.
hikaricore Wrote:So for example it would be clearart/True Blood/*.png ?
Would be quite nice and save renaming every clearart we download to fit the naming scheme.
<path>clearart/$INFO[TVSHOWTITLE]/</path>
reaven Wrote:without the .png justit will load all images in that folder regardless of extension.Code:<path>clearart/$INFO[TVSHOWTITLE]/</path>
Ram2000 Wrote:would this cause problems with fanart and season thumbs being in the same folder ?isn't suppose to cause any problem with anything because is not in the same folder is in a folder named clearart and even if they was in the same folder it wont cause a problem because it have a unique name so it wont mix with any other image, thats true with single cleartArt per show as of now. with multiimage cleaArt wont work because multiimage will load all the image in the folder specified if you put the clearArts in the tvshow folder it will load all the fanart and .tbn's images along with the cleaArts, so the solution would be put a cleaArt folder inside the tvshow folder or create a folder per tvshow under media folder.
I dont see any point in having multi images BUT maybe different season Images would be a better option ?
IE season one opens ClearartS1.png and when in season two it displays clearartS2.png
Just an idea
Ram2000 Wrote:I dont see any point in having multi imageswould be cool to see random clearArts everytime you paused or just for the heck of something different.
ppic Wrote:well that's a lot of work to do to make clearart for each season !!!would be cool as hell but a pain to make indeed !!
Quote:at Imaginoshey am thinking in changing the code so the clearArt be stored under the tvshow folder, what do you think ? that way you dont have to even rename the clearArt just name it "clearart"
reaven Wrote:...
like:
<Dexter>|
----------|<Season 1>
----------|<Season 2>
----------|tvshow.nfo
----------|season01.tbn
----------|season02.tbn
----------|season-all.tbn
reaven Wrote:hey am thinking in changing the code so the clearArt be stored under the tvshow folder, what do you think ? that way you dont have to even rename the clearArt just name it "clearart"
like:
<Dexter>|
Quote:That would be a much better idea for someone like me then i wouldn't have to copy the cleararts folder to every skin I have loaded.
would also get around issues with naming conventions.
reaven Wrote:do you have the clearArt mod working in others skins ?
