2009-06-05, 14:13
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
2009-06-05, 14:43
2009-06-05, 15:04
<texture diffuse="thumbs/movieposter_mask.png">path to the fanart</texture>
Path to fanart...is that supposed to be in the folder of your TV show? Should you use absolute paths like H:/TV Shows/Lost/lost.png? or just lost.png
The TV show title...<visible>VideoPlayer.Content(episodes) + substring(VideoPlayer.TVShowTitle), Lost </visible>.....would this be correct keeping a space at the begging and the end?
Tried this out yesterday but had no luck
2009-06-05, 19:13
2009-06-05, 19:48
mcborzu Wrote:<texture diffuse="thumbs/movieposter_mask.png">path to the fanart</texture>
I know how you feel, tried the same thing you said, no luck.
I can't figure it out.. don't mean to cause offense but the instructions are not simple for anyone that doesn't have a decent knowledge of code, if I could get this working I could photoshop a number of pictures for it.
2009-06-05, 19:51
This works pretty good :
This way, watching the simpsons wil use "media/cleararts/the simpsons.png".
but It's not a good solution, and I don't see any...
It doesn't seem possible to get the path of the video file, so it's impossible to use a clearart.png located in the show folder, and that is the only rigth option...
The only hope is that clearart is accepted by xbmc developpment and this info is stored in the DB.
<control type ="image">
<posx>950</posx>
<posy>-178</posy>
<width>330</width>
<height>185</height>
<texture diffuse="thumbs/movieposter_mask.png">cleararts/$INFO[VideoPlayer.TVShowTitle].png</texture>
<aspectratio align="right" aligny="bottom">keep</aspectratio>
<visible>VideoPlayer.Content(episodes)</visible>
</control>
2009-06-05, 19:57
Quote:<texture diffuse="thumbs/movieposter_mask.png">
why the mask ?
2009-06-05, 20:38
reaven Wrote:why the mask ?
I used the line from the mod linked in the begining of this thread.
I'm not sure it is usefull, I just tought there was a reason
2009-06-06, 00:39
2009-06-06, 00:52
Just finished a painstaking photoshop session, wasn't easy to make as I didn't use the magic wand because of the background so it was all eraser tool, but it seemed like the best CSI NY pic to use! So for anyone that wants a CSI: NY ClearArt here you go.
Full-size, Resolution=1599x1249 (they won't let me host the 2946x2301 version) :p:
http://i43.tinypic.com/1zn21bp.png
Resized:
Stock Image:
http://i44.tinypic.com/2yuc9c1.jpg
I haven't tested it because I can't get this mod to work yet, but I think it should be ok.
Btw, I have:
Inserted at the end of the .xml, is this incorrect ?
I created a folder @ "..skin/Aeon/media/ called cleararts and put 'Boston Legal.png' inside.
Resized:
Stock Image:
Btw, I have:
<control type="image">
<description>cover image episodes</description>
<posx>1049</posx>
<posy>-243</posy>
<width>230</width>
<height>250</height>
<texture diffuse="thumbs/movieposter_mask.png">cleararts/Boston Legal.png</texture>
<visible>VideoPlayer.Content(episodes) + substring(VideoPlayer.TVShowTitle), Boston Legal </visible>
</control>
<posx>1049</posx>
<posy>-122</posy>
<width>230</width>
<height>131</height>
<texture>thumbs/poster_glass.png</texture>
<!-- fix added code -->
<aspectratio align="right" aligny="bottom">scale</aspectratio>
<!-- end fix added code -->
</control>
2009-06-06, 01:54
if we use the <visible>...substring(VideoPlayer.TVShowTitle), Boston Legal </visible> condition, then we will have to make a control for each tvshow ! That's insane !
For the picture of CSI, you didnt' use the magnetic tool ? it woul have done the job in 2 min, using the mask mod after.
And by the way, you can reduce the picture to 500x281, it will be easier to store it, and it has to be resized to these dimensions anyway.
2009-06-06, 02:15
Imaginos Wrote:if we use the <visible>...substring(VideoPlayer.TVShowTitle), Boston Legal </visible> condition, then we will have to make a control for each tvshow ! That's insane !
Yeah I just wanted to see if I could actually get it to work ! I think you guys are right about it having to be implemented into xbmc itself.
Magnetic lasso would've worked great but something funny happens my photoshop when using it on a large image and using space+ L mouse
to navigate, I could've reduced it but wanted a big version in case I want to make a csi wallpaper :p
I'll make it smaller now anyways and edit my post.
2009-06-06, 02:18
Quote:if we use the <visible>...substring(VideoPlayer.TVShowTitle), Boston Legal </visible> condition, then we will have to make a control for each tvshow ! That's insane !I know, Thats because there isn't a command to grab the image, my xml have a control for each show, thats why I make a ticket but not for these, is for grab the currently playing tv show fanart for my other mod.
this is my DialogSeekbar.xml is missing some shows of course but is working, you would need to change the path and to remove the <texture=diffuse> part because theres no need for a mask with that image.
If i were you would try to move the code for where is suppose to be not at the end.
gallery updated !
2009-06-06, 02:23
2009-06-06, 02:36
Cool!!!...that code you had worked, thx Imaginos. Now photoshop time.
