Full Version: "ClearArt" concept - overlay type artwork for ex. 'episode poster/fanart on paused'
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
paul Wrote:Smart that matches my fanart just need to find the voyager and next generation and i'm sorted thanks for thatSmile
I'll hit you up with some Picard tomorrow No.1 :p
Ah screw it, engage !
I'll probably get through DS9 and maybe enterprise tomorrow if you like, I really need to get this mod to work Laugh
Quote:Cool!!!...that code you had worked, thx Imaginos.
Which ?, this one
<control type ="image">
    <posx>950</posx>
    <posy>-178</posy>
    <width>330</width>
    <height>185</height>
    <texture diffuse="thumbs/movieposter_mask.png">cleararts/$INFO[VideoPlayer.TVShowTitle].png</texture>
    <aspectratio align="right" aligny="bottom">keep</aspectratio>
    <visible>VideoPlayer.Content(episodes)</visible>
</control>
if you can confirm this that would be great so I can add it to the first page xml code.
gallery updated!
Yep this code works...
PHP Code:
posx>950</posx>
posy>-178</posy>
width>330</width>
height>185</height
control
Here's two shows:
nice
Since the code works, I will need to rename all the clearArts so it can match the tv show title, except the last two(Psych and Monk)
Gallery updated!
Oh good news. Whatever I did to my code the seek bar isn't showing anymore lol, can one of you put that working version on pastebin or something please ?
you need to put the code where is suppose to be I think is at first use the code I post in the first page as example
Heres mine...http://pastebin.com/f627d25b2...I put mine near the bottom.
I have mine after this
<control type="image">
                        <posx>0</posx>
                        <posy>0</posy>
                        <width>499</width>
                        <height>28</height>
                        <texture>osd/osd_button_reverse.png</texture>
                </control>
Ahh that's great thanks guys I have it now.
The problem I've discovered is with shows with semi-colons in the title such as CSI: NY. To create the png it needs to be called CSI: NY but Windows doesn't let you save files with ' : ' in the name.
The solution is to find the show in XBMC and edit title, for example rename 'CSI: NY' to 'CSI NY' and name your ClearArt 'CSI NY.png' and it works. Smile
complete DialogSeekBar.xml post it and fix it.
thanks Imaginos for the helpon the code you save a lot of writing and help me fix another mod, and thanks mcborzu for the confirmation.
on a side note I finish working on a fanart slideshow mod for musicVisualization have a look
new Dollhouse
Planet Earth
We're getting a good few now, here's another two Wink:
reaven Wrote:nice
Gallery updated!
But there will still remain a really big issue...
It will work only in english, that's precisly why we need it to be implemented in xbmc.
For example : The simpsons show :
In english, it wil search for "the simpsons.png" and in french "les simpson.png"
And lots of shows don't have a word in common !
the west wing => A la maison blanche
primeval => nick cutter et les portes du temps
DuMbGuM Wrote:We're getting a good few now, here's another two Wink:
Lol, TURK seats on void Smile
Haha yeah.
fixed these two to look better on light/dark backgrounds
http://i41.tinypic.com/16j1mxg.png
http://i39.tinypic.com/xmiiau.png
