Full Version: Triggering Button Clicks
Is it possible for one control to cause the click event to fire in another control, a button in this case?
The reason I ask is because I'm playing about with the System Info screen in MiniMeedia and have noticed that the way the PM3.HD System Info screen is now put together relies on hard-coded click events on buttons with specific id's.
Unfortunately the design for my system info screen won't work with buttons so I'd like to make those buttons invisible and have other controls cause the click events to fire on them.
Is this possible at the moment or will I need to add an entry to trac to request it?
SendClick(window,controlID) might do the trick?
Cheers,
Jonathan
Excellent, thanks. Will give it a try
Works a treat! Big Grin Thanks
