Hi there,
I've created a new Full Screen Visualisation for Aeon which only includes the most important things (including AlbumtArt).
You only have to replace the content of MusicVisualisation.xml located in /skin/aeon/720p with the following code:
http://pastebin.com/f4d8d0d6d
Enjoy!
Further developement, same procedure.
With previous and next song.
http://pastebin.com/f2f5c8ac5
Great, thanks! I like it minimal
Just if you accept requests
... is it possible to add the codec and bitrate or the previous and next track?
Perhaps like this:
Something like this would be perfect for me!
Edit:
I thought about something like this (just work with minimal osd):
The xml:
http://pastebin.com/m4e5ff5f3
iddqd Wrote:I played a little bit more...
Big cover without seekbar (max view):
Big cover with seekbar (max view):
Minimal view for both:
Big cover without seekbar xml: http://pastebin.com/m9deba78
Big cover with seekbar xml: http://pastebin.com/m5ab00c4b
Png for both (copy to /media/home/nowplayingmod_info.png): http://img39.imageshack.us/img39/4576/no...odinfo.png
i really like this view, but i can't get it to work......i can only get the first post in the thread to work. I would skip the codec part.....i'm not interested in the codecs etc....just want to know the artist, album, song, time, next, previous.
any idea's how to get this to work? i only get a now playing bar at the top.
now that i think of it....why not copy paste the code directly from the main home menu....that now playing view is perfect, just put it down a few inches and you're done (although i understand that it's not that easy)
redje Wrote:now that i think of it....why not copy paste the code directly from the main home menu....that now playing view is perfect, just put it down a few inches and you're done (although i understand that it's not that easy)
Well, that's basically what I've done
How come you guys all want to know the name of the previous and next song? Is this any useful?
@iddqd: Nice work
thanks it works, nice one
Grrzzz Wrote:Well, that's basically what I've done
@iddqd: Nice work
when in playlist shuffled or you want to look for the best album track, etc....there are tons of reasons why to have a next song (previous doesn't matter to me actually)
Ok, one more...
This time it's not really minimal but with big cover
If somebody likes it, here are the files:
xml file
The png's must be saved as /media/osd/osd_background_big.png respectively /media/osd/osd_button_codec.png.
I adapt the first one.
Copy the
png to /media/home/nowplayingmod_info.png and take this
xml if you like codec etc. or take this
xml if you don't like codec etc.
Edit: Updated xml (corrected slide effect).
