Full Version: Sorting music: Alphabet -> Artist -> Album -> Tracks
Hi all!
I struggling with my music library, navigating takes to long with my amount of music. To find desired artist i need to scroll for ages with my remote. Is it another way?
I would like this view in my music section:
Is this possible? How do you guys navigate quickly in your library?
Pressing Shift + Letter will take you that point in the library.
For example if you are looking at a list of Artists then clicking Shift + S will take to the first artist beginning with S.
Depending on which view you are using, there may also be a scrollbar that you can use for quicker navigation.
skunkm0nkee Wrote:Pressing Shift + Letter will take you that point in the library.
Scrollbar! And todays idiot is... me! Thank you, its working better now Wink
