I added all my music to my music library but now i want to get rid of it all. I removed my mp3 folder as a source but when i hit update library it still scans the folder and all the music is still there...
how do i get rid of all my music?
Settings > Music > Library > Clean Library.
alternatively just delete the musicdb out of your profile folder!
clean library didn't work for some reason...i'm a xbmc noob...where would i find the musicdb? i don't see a profiles folder in my xbmc folder
awesome....thanks a lot guys
I feel like this shouldn't need to be asked, but how do I remove 1 item from the music library, ie one album that I don't want anymore? context menu doesn't have a delete option, and pressing delete does nothing...
Nevermind, I found the answer, even though I feel it should work better than having to physically move or delete the files...
http://forum.xbmc.org/showthread.php?tid...move+music
How do you mean "You don't want it".
Do you want the files gone, or do you want it just out of the library?
jmarshall Wrote:How do you mean "You don't want it".
Just want it out of the library, the thread that I referred to seems like a workaround rather than a function of xbmc....
The problem is that if the files are still present then we need a way of ignoring them in the future. Once they're ignored, how does one add them back in at a later date.
On a more basic level, however, I'm not sure I understand the need for not including an album when it's there among all your other music? I can, on the other hand, understand the need for wanting to get rid of it altogether (i.e. removal of files as well as from the library).
Cheers,
Jonathan
I just thought that if the functionality was in the movie library it'd be in music, though as per your question, I was wanting to remove several item from my music library so I could fix thier ID3 tags and then add them back in, though I guess I could just fix them and do an update library.
Indeed - that is the desired behaviour - no need to remove stuff when you can just update their tags then update lib.
I suspect if you tell the movie library to remove the item and then do an update they'll pop back up again as well.
jmarshall Wrote:The problem is that if the files are still present then we need a way of ignoring them in the future. Once they're ignored, how does one add them back in at a later date.
Cheers,
Jonathan
yes, it would be great to be able to delete from inside the library (so you can remove a specific song (file), or a whole group of files based on the id3tags like album or artist.
There is still no easy way to remove a scanned item from your music library
why is there no REMOVE FROM LIBRARY in the context menu?
You can delete the files from the library if you enable file rename/delete I think?
