Gujs Wrote:What version of ubuntu did yo use? If you have 9.10 than it should work. And it would be great if you paste an error here, I would like to see what went wrong.
I am using Lucid Lynx (64bits). It seems a problem with dependencies.
Quote:$ sudo apt-get install xbmc
Reading package lists ... Fact
Building dependency tree
Reading state information ... Fact
We were unable to install some packages. This may mean that
you have requested an impossible situation or if you are using the distribution
distribution that some required packages have not been created or
been moved out of Incoming.
The following information may help resolve the situation:
The following packages have unmet dependencies:
xbmc: Depends: xbmc-data (= 1:9.11 + svn29489.lucid2) but it will not install
Depends: xbmc-skin-confluence (= 1:9.11 + svn29489.lucid2) but it will not install or
xbmc-skin-pm3-hd (= 1:9.11 + svn29489.lucid2) but it will not install
Depends: xbmc-web (= 1:9.11 + svn29489.lucid2) but it will not install
E: Broken packages
xbmc-data: Depends: xbmc-bin (> = 1:9.11 + svn29489.lucid2) but it is not installable
Depends: xbmc-bin (<1:9.11 + svn29489.lucid2.1 ~) but it is not installable
E: Broken packages
Xbmc-bin package is not available, but referred to by another package
him. This may mean that the package is missing, outdated or just
available from another source
E: xbmc-bin package has no installation candidate
Hi, how is possible switch channel directly into XBMC+TVHeadend ?
if i have:
1) tv_a
2) tv_b
3) tv_c
and if i press 1+enter then xbmc switch to channel 2 (tv_b)...
thanks
I prepared new packages, which were tested with lucid 64 bit and karmic 32 bit.
I am still looking what is wrong with channel change. Do you guys have the same problem, or is it just me? And does somebody knows if vdr-vnsi works good when changing channels?
I'm getting very bad flickering on your build from today when watching videos. The video and the osd itself flicker.
Was working fine in the previous build.
I'm using a 7 inch pc (o2 joggler) so not a great test but didnt have any problems like this with last build.
I'm using the karmic build btw
I don't see anything like that. Please look into the logs, if there is anything strange there. I build these packages the same way as before.
Do you use any hw acceleration (vdpau or vaapi)? And what kind of content do you play?
Thanks Gujs. The problem with the installation in Lucid (64) has been solved.
I have also problems with changing channels by number or by the arrows, but if I select each channel from the livetv list then works fine. I am using a DVB-T card with tvheadend.
Well, trying to figure out what this program does and what the requirements are hardware wise. So I went to
http://www.lonelycoder.com to gather some more info and it only displays an index page. So no file to download either.
So, is this a web tv program or do I need a DVB-S/T card?
I have a pinnacle hdtv card, but I fail to see what good that is unless I tap into a comcast cable network. I do have dish, and I am looking to see if there is a way to connect into the HD pvr.
Anyone point me to a site that has hardware requriements for the use of tvheadend and maybe what it is all about?
speed32219 Wrote:Well, trying to figure out what this program does and what the requirements are hardware wise. So I went to http://www.lonelycoder.com to gather some more info and it only displays an index page. So no file to download either.
Here you go
http://www.lonelycoder.com/hts/tvheadend_overview.html
I just uploaded new version to my ppa. In this one I fixed channel change and added audio and subtitle audio detection. I will appreciate for any feedback about channel changing fix?
I also submitted trac ticket if someone wants to compile it itself:
http://trac.xbmc.org/ticket/9300
Gujs Wrote:I just uploaded new version to my ppa. In this one I fixed channel change and added audio and subtitle audio detection. I will appreciate for any feedback about channel changing fix?
Stupid question of the day!!! where do i find details of this PPA
Great work, Gujs! Now channel changing works like a charm.
Yes it is last svn from the pvr-testing branch.
xbmcuser2000 I am glad that it works for you.
