Hello,
i'm using that skin with my xbox and i have no idea how to get those little icons in my movie view (paramount, fox, 20centuries etc)
did i miss any settings? or is this feature just not available with the xbox?
thanks,
chris
H3lium Wrote:Hello,
thanks,
chris
No,you just have to rescan your library.
Hi ZIOLele,
i did that already a couple times.
It is safed in the movieinformation. When i open the movie informations, its written underneath the "studio" but without any icon...
double post
It's strange, because to see the studio icons i've had to rescan, but nothing else and i'm using minimedia on xbox
Do clear your video database in your userdata folder.
Located here:
XBMC\userdata\Database\MyVideos34.db
And do also clear you video thumbs.
located here:
XBMC\userdata\Thumbnails\Video.
Now set content again to your movie folder.
Edit:
Advice, use an external scraper first to get full control over your library.
And have the abbillity to resize the fanart. It's needed for the xbox to run smooth. Mine are all 1280x720.
I use Media Companion, there are more external scrapers.
i deleted both!
takes ages, to scan the libary again... and download all the art
external scrapers dont really work for me, since i have all data only on my xbox.
but still, nothing has changed.
if i open the movie information it does say the studio. but theres no way, minimedia would show it in any showcase
any other suggestions?
