dallasnights Wrote:Can anyone help me find a way to show the animated weather icons missing as shown in post 202 please for the confluence weather mod
thanks
Can you post your xbmc.log file and the skin mod you're using?
fmartel77 Wrote:Hi all, I' kinda new to XBMC..
So I found out a few things... Though there's one thing I'd like it to do for the waether... If I could have it in °C.
here is the formula : [°C] = ([°F] − 32) ⁄1,8
Ex : (50 − 32) = 18, then 18⁄1,8 = 10
System > Appearance > International
Set both Language and Region to the correct values for your location.
ronie Wrote:System > Appearance > International
Thanks for the swift answer !
It works !! Thanks !!
I uploaded weather.com+ for Dharma addon onto nuka's repo.
So you can install and update from the repo.
[NOTE] I added "codes.txt" file in this addon's folder. It'll be updated if any code changes or addition, so I expect skinners can use the txt file as a reference easily.
nuka1195's repo :
http://xbmc-addons.googlecode.com/svn/pa...addons.zip
brightstr I am using Confluence Mod Movie Sets skin
I took all confluence files for weather and put into this directory
/private/var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets
Here is the LOG thanks for your help
06:40:09 T:151834624 M:106586112 INFO: load skin from:/var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets
06:40:09 T:151834624 M:103440384 INFO: Default 4:3 resolution directory is /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets/720p
06:40:09 T:151834624 M:103440384 INFO: Default 16:9 resolution directory is /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets/720p
06:40:09 T:151834624 M:103440384 INFO: Loading skin includes from /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets/720p/includes.xml
06:40:11 T:151834624 M:128352256 INFO: load fonts for skin...
06:40:11 T:151834624 M:128364544 INFO: Loading fonts from /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets/720p/Font.xml
06:40:11 T:151834624 M:128102400 INFO: load new skin...
06:40:11 T:151834624 M:128102400 INFO: Loading skin file: Home.xml
06:40:11 T:151834624 M:128131072 WARNING: Skin has invalid include: HomeSubMenuVideos
06:40:11 T:151834624 M:128131072 WARNING: Skin has invalid include: HomeSubMenuMusic
06:40:11 T:151834624 M:128131072 WARNING: Skin has invalid include: HomeSubMenuPictures
06:40:11 T:151834624 M:128131072 WARNING: Skin has invalid include: HomeSubMenuSystem
06:40:11 T:151834624 M:128131072 WARNING: Skin has invalid include: HomeSubMenuPrograms
06:40:11 T:151834624 M:128131072 WARNING: Skin has invalid include: HomeSubMenuMovies
06:40:11 T:151834624 M:128131072 WARNING: Skin has invalid include: HomeSubMenuTVShows
06:40:11 T:151834624 M:128131072 INFO: Loading user windows, path /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets/720p
06:40:12 T:151834624 M:128319488 DEBUG: Load Skin XML: 337.82ms
06:40:12 T:151834624 M:128319488 INFO: initialize new skin...
06:40:12 T:151834624 M:128319488 INFO: Loading skin file: Pointer.xml
06:40:12 T:151834624 M:128303104 INFO: Loading skin file: DialogVolumeBar.xml
06:40:12 T:151834624 M:128303104 INFO: Loading skin file: DialogSeekBar.xml
06:40:12 T:151834624 M:128303104 INFO: Loading skin file: DialogKaiToast.xml
06:40:12 T:151834624 M:128303104 INFO: Loading skin file: DialogMuteBug.xml
06:40:12 T:151834624 M:128299008 INFO: Loading skin file: DialogKaiToast.xml
06:40:12 T:151834624 M:128294912 INFO: Loading skin file: DialogSeekBar.xml
06:40:12 T:151834624 M:128282624 INFO: Loading skin file: DialogBusy.xml
06:40:12 T:151834624 M:128282624 DEBUG: CGUIAudioManager::Initialize
06:40:12 T:151834624 M:128282624 DEBUG: Previous line repeats 1 times.
06:40:12 T:151834624 M:128282624 INFO: Loading /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.moviesets/sounds/sounds.xml
06:40:12 T:151834624 M:128282624 INFO: skin loaded...
06:40:12 T:151834624 M:128282624 DEBUG: Activating window ID: 10019
06:40:12 T:151834624 M:128282624 DEBUG: Checking if window ID 10019 is locked.
06:40:12 T:151834624 M:128282624 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
06:40:12 T:151834624 M:128282624 DEBUG: ------ Window Init (SettingsCategory.xml) ------
06:40:12 T:151834624 M:128282624 INFO: Loading skin file: SettingsCategory.xml
06:40:12 T:151834624 M:128278528 ERROR: Window Translator: Can't find window scriptsdebuginfo
06:40:12 T:151834624 M:128278528 ERROR: Window Translator: Can't find window pluginsettings
06:40:12 T:151834624 M:128278528 ERROR: Error evaluating boolean expression Window.IsActive(MovieInformation) | Window.IsActive(MusicInformation) | Window.IsActive(SongInformation) | Window.IsActive(FileBrowser) | Window.IsActive(ScriptsDebugInfo) | Window.IsActive(PluginSettings) | Window.IsActive(ContentSettings) | Window.IsActive(SelectDialog) | Window.IsActive(FileStackingDialog) | Window.IsActive(MediaSource) | Window.IsActive(PictureInfo) | Window.IsActive(PlayerControls) | Window.IsActive(VirtualKeyboard) | Window.IsActive(NumericInput) | Window.IsActive(ProfileSettings) | Window.IsActive(LockSettings) | Window.IsActive(SmartPlaylistEditor) | Window.IsActive(SmartPlaylistRule) | Window.IsActive(script-Apple_Movie_Trailers-settings.xml) | Window.IsActive(script-Apple_Movie_Trailers-chooser.xml) | Window.IsActive(script-Apple_Movie_Trailers-search.xml) | Window.IsActive(script-Apple_Movie_Trailers-showtimes.xml) | Window.IsActive(script-XBMC_Lyrics-settings.xml) | Window.IsActive(script-RSS_Editor-rssEditor.xml) | Window.IsActive(script-RSS_Editor-setEditor.xml)
06:40:12 T:151834624 M:128229376 DEBUG: ADDON: cpluff: 'Could not return information about unknown plug-in script.rss.editor.'
06:40:13 T:174563328 M:112377856 DEBUG: Previous line repeats 1 times.
06:40:13 T:174563328 M:112377856 DEBUG: DoWork - took 419 ms to load special://skin/backgrounds/settings.jpg
dallasnights Wrote:brightstr I am using Confluence Mod Movie Sets skin
applying a mod to an already modded skin is likely to cause breakage.
Ok then how do I apply it to the non-modded Confluence
when I put all the files in /Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/skin.confluence
the main screen becomes black and shows nothing
Thanks for your help
dallasnights Wrote:Ok then how do I apply it to the non-modded Confluence
having two copies of the same skin in your addons folder is likely to cause breakage too.
not sure if that's your issue though...
Thanks for the thought, but that is not the issue, I tried your idea and only had one confluence, in the directory mentioned above and unistalled moviesets and still it gave me a big black home screen with no menus,
Anyone have any other ideas
Thanks all
brightsr Wrote:I uploaded weather.com+ for Dharma addon onto nuka's repo.
nuka1195's repo : http://xbmc-addons.googlecode.com/svn/pa...addons.zip
ronie Wrote:here's an updated version of Nuka1195's mod for Confluence:
Confluence_weather_mod.zip
screenshots can be found in the old thread:
http://forum.xbmc.org/showthread.php?tid=66261
uhm, it seems that the mod is for the old (9.10 confluence)
from the log
6:01:17 T:3078453120 M:1189773312 WARNING: Skin has invalid include: AddonInfoListView1
16:01:17 T:3078453120 M:1189773312 WARNING: Skin has invalid include: LiveTVView1
16:01:17 T:3078453120 M:1189773312 WARNING: Skin has invalid include: AddonInfoListView1
16:01:17 T:3078453120 M:1189773312 ERROR: Window Translator: Can't find window scriptsdebuginfo
16:01:17 T:3078453120 M:1189773312 ERROR: Window Translator: Can't find window pluginsettings
16:01:17 T:3078453120 M:1189773312 ERROR: Error evaluating boolean expression Window.IsActive(MovieInformation) | Window.IsActive(MusicInformation) | Window.IsActive(SongInformation) | Window.IsActive(FileBrowser) | Window.IsActive(ScriptsDebugInfo) | Window.IsActive(PluginSettings) | Window.IsActive(ContentSettings) | Window.IsActive(SelectDialog) | Window.IsActive(FileStackingDialog) | Window.IsActive(MediaSource) | Window.IsActive(PictureInfo) | Window.IsActive(PlayerControls) | Window.IsActive(VirtualKeyboard) | Window.IsActive(NumericInput) | Window.IsActive(ProfileSettings) | Window.IsActive(LockSettings) | Window.IsActive(SmartPlaylistEditor) | Window.IsActive(SmartPlaylistRule) | Window.IsActive(script-Apple_Movie_Trailers-settings.xml) | Window.IsActive(script-Apple_Movie_Trailers-chooser.xml) | Window.IsActive(script-Apple_Movie_Trailers-search.xml) | Window.IsActive(script-Apple_Movie_Trailers-showtimes.xml) | Window.IsActive(script-XBMC_Lyrics-settings.xml) | Window.IsActive(script-RSS_Editor-rssEditor.xml) | Window.IsActive(script-RSS_Editor-setEditor.xml)
16:01:17 T:3078453120 M:1189773312 WARNING: Skin has invalid include: SideBladeLeft
16:02:35 T:3078453120 M:1190187008 WARNING: Previous line repeats 1 times.
I cannot tell if there is any visual impact as I'm flying by wire
- I applied the mod remotely
wazzer99 Wrote:uhm, it seems that the mod is for the old (9.10 confluence)
from the log
<snip>
I cannot tell if there is any visual impact as I'm flying by wire - I applied the mod remotely
I don't think it does. I made a copy of my confluence skin, renamed it (both the folder and in the XML), applied the mods listed at the link, and it seems to be working fine, at least as far as I can tell.
heh...you're right...
although it wasn't causing any major damage,
it's still pretty silly of me not to think about that.
anyways, i've fixed all possible issues:
Thank you now I have redone my ATV last night, clean start, I now have one Conlfuence here onmy ATV2
I took the files you menitioned above, put them into this directory, first is that correct?
Next I rebooted the ATV, back into XBMC and the home screen is totally black no menus nothing
So the question is what am I doing wrong can anyone help me, am I putting the files in teh correct directory??
Thanks all and thanks Ronie
Since downloading the map icons using the configuration menu doesn't seem to be working, I manually downloaded the zip file from the first posting. However, I wasn't able to find anything specifying where the files should be placed. Can someone tell me what directory the map icon files should be unzipped into?
