dallasnights Wrote:no i did not i just checked and it seems they were never there i think, do you have a weather.zip in Applications/XBMC.frappliance/XBMCData/XBMCHome/media/weather.zip
Nope...
No weather.zip anyplace
if you go into the weather settings and set it for the basic weather(the original), do you have images then.
no i never did have images there, so hmm what does that tell you
YES its a clean install BTW, from scratch yesterday, r
YES the icons show on Tranparency Skin
so hmm
See below with transparency skin
dallasnights Wrote:I found the weather.zip file here i think..... and tried to put it in the directory as noted, but still does not work
http://xbmc.exstatic.org/weather_fanart/
I just installed the weather on my ATV2 and I have no icons either. I will locate and add..
cool thanks for your help
On my iPad I had that file in that location and everything worked.
On my ATV2 that file wasn't there and I had no graphics. I copied the weather.zip file from my iPad to the ATV2 and Viola I had graphics..
you are 100% right thanks, installed on my iphone 4, then transferred the file to my ATV and it works, thank you nice catch!
ronie Wrote:unzip wherever you like, then check this post:
http://forum.xbmc.org/showpost.php?p=722...tcount=182
I unzipped the map icon files, and edited guisettings.xml to point to them as follows:
<setting type="string" name="skin.confluence.TWC.mapiconpath">\Users\richard\AppData\Roaming\XBMC\userdata\addon_data\weather.weatherplus\MapIconPack-small</setting>
But the skin is still not displaying the icons.
Any ideas what might be wrong?
richardk Wrote:I unzipped the map icon files, and edited guisettings.xml to point to them as follows:
add a \ at the end of the path.
2 quick questions ronie or anyone that can help
on the 36 hour forecast it shows
Sunrise 8:06
Sunset 19:15
First its wrong for DST (daylight savings time), how can I fix this, second how can I make sunset 12 hour clock instead of 24 hour clock so the correct is
Sunrise 7:06
Sunset 6:15
BTW I have corrected the time on my AppleTV and it is correct
What files do I edit?
ronie Wrote:add a \ at the end of the path.
Thanks for the reply, but that didn't make any difference.
Just wondered if there are any other UK users who have tried the weather report video from Sky? When I play it the video is fine but the audio stutters really badly. Changed my location to NYC and the weather report video and audio plays perfectly. No problem when going to the Sky website and watching the weather report there.
[UPDATE] v.1.1.7
Fixed : Current Pressure, Visibility, Sunrise, Sunset
