Hi, that happend with last xbmc revision and the last auriga (not git, the .zip).
I tried with other skins and no problem
Windows vista ultimate 64bits.
That's a part of the debug log
09:47:34 T:2912 M:2577428480 DEBUG: Win32DllLoader::Unload ImageLib.dll
09:47:34 T:2912 M:2577428480 DEBUG: FreeLibrary(MSVCR71.dll) -> 0515A210
09:47:34 T:2912 M:2577428480 DEBUG: FreeLibrary(MSVCP71.dll) -> 0515B7A0
09:47:34 T:2912 M:2577428480 DEBUG: Win32DllLoader::Unload MSVCP71.dll
09:47:34 T:2912 M:2577428480 DEBUG: Win32DllLoader::Unload MSVCR71.dll
09:47:34 T:2912 M:2578927616 DEBUG: CLastfmScrobbler: Journal with 0 entries saved to special://masterprofile/LastfmScrobbler.xml
09:47:34 T:2912 M:2578923520 DEBUG: CLibrefmScrobbler: Journal with 0 entries saved to special://masterprofile/LibrefmScrobbler.xml
09:47:34 T:2904 M:2566578176 DEBUG: Thread 2904 terminating
09:47:34 T:2904 M:2566541312 FATAL: EXCEPTION_ACCESS_VIOLATION (0xc0000005)
at 0x007871f1
09:47:34 T:3288 M:2566148096 DEBUG: Thread 3288 terminating
09:47:34 T:3288 M:2566148096 FATAL: EXCEPTION_ACCESS_VIOLATION (0xc0000005)
at 0x007871f1
PD: sorry my english.
Same here. Will also post the debug log this evening if it can help
Same issue here. I first thought it's because of the SVN build, but it really seems only to happen with Aeon.
Here is a part of my debug log:
12:35:41 T:2988 M:2478288896 NOTICE: load default skin:[Aeon Auriga]
12:35:41 T:2988 M:2474041344 WARNING: file doesnt have <fontset> with name 'Default', defaulting to first fontset
12:35:41 T:2988 M:2464456704 ERROR: unable to load:special://xbmc/skin/Aeon Auriga/720p/Pointer.xml, Line 0
Failed to open file
12:35:41 T:2988 M:2462146560 NOTICE: initialize done
12:35:41 T:2988 M:2462187520 NOTICE: Running the application...
12:35:41 T:2988 M:2462064640 NOTICE: ES: Starting event server
12:35:41 T:2568 M:2461896704 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
12:35:41 T:2568 M:2461888512 NOTICE: UDP: Listening on port 9777
12:36:29 T:2988 M:2416128000 WARNING: Skin has invalid include: MediaBackdropsTVFanart
12:36:29 T:2988 M:2416336896 WARNING: Skin has invalid include: MediaBackdropsTVFanart
12:36:29 T:2988 M:2416340992 WARNING: Skin has invalid include: MediaBackdropsTVFanart
12:43:38 T:2988 M:2408591360 NOTICE: Storing total System Uptime
12:43:38 T:2988 M:2408591360 NOTICE: Saving settings
12:43:38 T:2988 M:2408300544 NOTICE: stop all
12:43:38 T:2988 M:2408300544 NOTICE: ES: Stopping event server
12:43:38 T:2568 M:2407682048 NOTICE: ES: UDP Event server stopped
12:43:38 T:2988 M:2407620608 NOTICE: stop dvd detect media
12:43:38 T:2988 M:2407628800 NOTICE: stop sap announcement listener
12:43:38 T:2988 M:2407645184 NOTICE: clean cached files!
12:43:38 T:2988 M:2407636992 NOTICE: unload skin
12:43:38 T:2988 M:2416353280 NOTICE: stop python
12:43:38 T:2988 M:2416353280 NOTICE: stopped
12:43:38 T:2988 M:2416353280 NOTICE: destroy
12:43:38 T:2988 M:2416320512 NOTICE: unload sections
12:43:39 T:808 M:2463133696 FATAL: EXCEPTION_ACCESS_VIOLATION (0xc0000005)
at 0x007871f1
and this is how it looks with additional debugging information
13:07:47 T:2960 M:2367283200 DEBUG: CNetwork::NetworkMessage - Stopping network services
13:07:47 T:2960 M:2367279104 NOTICE: ES: Stopping event server
13:07:47 T:3804 M:2368450560 NOTICE: ES: UDP Event server stopped
13:07:47 T:3804 M:2368450560 DEBUG: Thread 3804 terminating
13:07:47 T:2960 M:2368475136 DEBUG: CLastfmScrobbler: Journal with 0 entries saved to special://masterprofile/LastfmScrobbler.xml
13:07:47 T:2960 M:2368462848 DEBUG: CLibrefmScrobbler: Journal with 0 entries saved to special://masterprofile/LibrefmScrobbler.xml
13:07:47 T:2960 M:2368454656 NOTICE: stop dvd detect media
13:07:47 T:940 M:2368454656 DEBUG: Thread 940 terminating
13:07:47 T:2960 M:2368483328 NOTICE: stop sap announcement listener
13:07:47 T:2960 M:2368487424 NOTICE: clean cached files!
13:07:47 T:2960 M:2368479232 NOTICE: unload skin
13:07:47 T:2960 M:2377416704 NOTICE: stop python
13:07:47 T:2960 M:2377408512 NOTICE: stopped
13:07:47 T:2960 M:2377408512 NOTICE: destroy
13:07:47 T:2960 M:2377359360 NOTICE: unload sections
13:07:47 T:2960 M:2377359360 DEBUG: SECTION:UnloadAll(DLL: special://xbmc/system/libcurl.dll)
13:07:47 T:2960 M:2377359360 DEBUG: Win32DllLoader::Unload libcurl.dll
13:07:47 T:2960 M:2377359360 DEBUG: FreeLibrary(MSVCR71.dll) -> 021505C8
13:07:47 T:2960 M:2377924608 DEBUG: SECTION:UnloadAll(DLL: special://xbmc/system/ImageLib.dll)
13:07:47 T:2960 M:2377924608 DEBUG: Win32DllLoader::Unload ImageLib.dll
13:07:47 T:2960 M:2377924608 DEBUG: FreeLibrary(MSVCR71.dll) -> 021505C8
13:07:47 T:2960 M:2377924608 DEBUG: FreeLibrary(MSVCP71.dll) -> 02172E00
13:07:47 T:2960 M:2377924608 DEBUG: Win32DllLoader::Unload MSVCP71.dll
13:07:47 T:2960 M:2377924608 DEBUG: Win32DllLoader::Unload MSVCR71.dll
13:07:47 T:2960 M:2379493376 DEBUG: CLastfmScrobbler: Journal with 0 entries saved to special://masterprofile/LastfmScrobbler.xml
13:07:47 T:2960 M:2379481088 DEBUG: CLibrefmScrobbler: Journal with 0 entries saved to special://masterprofile/LibrefmScrobbler.xml
13:07:48 T:1104 M:2425110528 DEBUG: Thread 1104 terminating
13:07:48 T:1104 M:2425090048 FATAL: EXCEPTION_ACCESS_VIOLATION (0xc0000005)
at 0x007871f1
Greetings! I am certain that this is not a skin/aeon related issue since the problem with "fatal: exception access violation" seems to affect WIN32 SVN builds after >Rev20440. Try and revert back to Rev20440 and see if that solves the problem.
In my case I was getting the same error on my log most of the times when I closed XBMC "ALT+F4" but reverting back to Rev20440 solved this issue. I've checked the update logs on the newer builds and I'm not sure what source changes could have caused this. Cheers
I use mediastream and mine crashes now as well. So it may not be the skin.
UPDATE: The crash on exit violation issue seems to be solved now starting from build >> (#20838 and 20855 >>) At least in my case when it comes to the W32 builds. They are still not available in the official XBMC-SVN-updates yet. But you can download the latest unofficial XBMC Nightly Builds from the link below:
http://www.sshcs.com/xbmc/
