Full Version: [LIVE] Kernel upgrade with FireDTV drivers and TVheadend for the next XBMC Live?
I'd like to see a kernel upgrade from 2.6.28 to 2.6.29 in de next LIVE build, with the included drivers for FireDTV/FloppyDTV from DigitalEverywhere.
http://www.digital-everywhere.com/en/alc....php?start
With these drivers we can use the liveTV feature of tvheadend together with XBMC.
http://www.xbmc.org/forum/showthread.php...=tvheadend
The DVB-C version of this card is about the only card that can be used for the Dutch cable companies. So I think alot of Dutch people will use this.
Sounds like a great idea!
We don't really mess with the base system so this won't likely happen until ubuntu goes to 2.6.29. AFAIK you can do all the tvheadend stuff on a server (which you can update the kernel on as you see fit) elsewhere and you your XBMC box as a client now though.
