I downloaded the AEON STARK onto my xbox. The problem is that it doesn't run well, its slow also i get wierd screen problem. Like the screen is perfect when i enter the settings, but when i enter the interface the screen starts to shake. i don't know if i download the wrong one for xbox.
I'll provide pictures later, thanks in advance.
forget about aeon and xbox, it will never play well. not even in butchered versions
help yourself... by reading.
and spiff you are VERY wrong. Pauls xbox lite build, 960x540 fanart works perfectly.
diemos Wrote:help yourself... by reading.
What do you expect they hate it when they get proved wrong, i were told it would never work on xbox so i decided to prove them wrong. Long live the xbox
Ps thanks for the kind words diemos.
depends on the eye that view them. the low framerate is not what i consider usable.
