Full Version: [Apple TV] Errors After Reinstall
I hope someone can help me with this problem. I was successfully using XBMC on my Apple TV. I had to restore the factory defaults on the Apple TV, so after I upgraded the ATV software, I reinstall XBMC.
However since then, XBMC won't remember any video sources. I connect it to my Apple Time Capsule using Add Video Source, and it connects and I can watch videos. After exiting and restarting XBMC, the Time Capsule video source has disappeared. I'm not sure where the problem is, but I found a lot of db and file access errors in the xbmc.log.
Any help would be most appreciated!
-bash-2.05b$ cat xbmc.log
21:44:23 T:2684407808 M: 58503168 NOTICE: Mapping drive Z to /tmp/xbmc
21:44:23 T:2684407808 M: 58499072 NOTICE: Mapping drive Q to /Applications/XBMC.app/Contents/Resources/XBMC
21:44:23 T:2684407808 M: 58490880 NOTICE: Mapping drive U to /Users/frontrow/Library/Application Support/XBMC
21:44:23 T:2684407808 M: 58490880 NOTICE: Mapping drive T to /Users/frontrow/Library/Application Support/XBMC/userdata
21:44:23 T:2684407808 M: 58540032 WARNING: CopyFile, cant open file </Applications/XBMC.app/Contents/Resources/XBMC/userdata/Lircmap.xml>. trying to use lowercase </applications/xbmc.app/contents/resources/xbmc/userdata/lircmap.xml>
21:44:23 T:2684407808 M: 58535936 ERROR: CopyFile - cant open source file </Applications/XBMC.app/Contents/Resources/XBMC/userdata/Lircmap.xml>
21:44:23 T:2684407808 M: 58540032 NOTICE: -----------------------------------------------------------------------
21:44:23 T:2684407808 M: 58540032 NOTICE: Starting XBMC, Platform: Mac OS X. Built on Dec 18 2008
21:44:23 T:2684407808 M: 58540032 NOTICE: Q is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
21:44:23 T:2684407808 M: 58540032 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
21:44:23 T:2684407808 M: 58540032 NOTICE: Log File is located: /Users/frontrow/Library/Logs/xbmc.log
21:44:23 T:2684407808 M: 58540032 NOTICE: Setup SDL
21:44:24 T:2684407808 M: 56987648 NOTICE: load settings...
21:44:24 T:2684407808 M: 56987648 NOTICE: Mapping drive P to special://masterprofile
21:44:24 T:2684407808 M: 56987648 NOTICE: loading /Users/frontrow/Library/Application Support/XBMC/userdata/guisettings.xml
21:44:24 T:2684407808 M: 56938496 NOTICE: Getting hardware information now...
21:44:24 T:2684407808 M: 56938496 NOTICE: Checking resolution 10
21:44:24 T:2684407808 M: 56938496 NOTICE: Setting autoresolution mode 3
21:44:24 T:2684407808 M: 56930304 NOTICE: Loaded advancedsettings.xml from /Users/frontrow/Library/Application Support/XBMC/userdata/advancedsettings.xml
21:44:24 T:2684407808 M: 56930304 NOTICE: Getting hardware information now...
21:44:24 T:2684407808 M: 56930304 NOTICE: Checking resolution 10
21:44:24 T:2684407808 M: 56930304 NOTICE: Setting autoresolution mode 3
21:44:24 T:2684407808 M: 56930304 NOTICE: special://masterprofile/sources.xml
21:44:24 T:2684407808 M: 56930304 ERROR: Load Error loading special://masterprofile/sources.xml: Line 0, Failed to open file
21:44:24 T:2684407808 M: 56926208 ERROR: Create - Error creating P:\playlists\
21:44:24 T:2684407808 M: 56926208 ERROR: Create - Error creating special://masterprofile/playlists/music
21:44:24 T:2684407808 M: 56926208 ERROR: Create - Error creating special://masterprofile/playlists/video
21:44:24 T:2684407808 M: 56926208 ERROR: Create - Error creating special://masterprofile/playlists/mixed
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/>. trying lower case.
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/Database>. trying lower case.
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/Database/CDDB>. trying lower case.
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/Thumbnails>. trying lower case.
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/Thumbnails/Music>. trying lower case.
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/Thumbnails/Music/Artists>. trying lower case.
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/Thumbnails/Music/LastFM>. trying lower case.
21:44:25 T:2684407808 M: 48926720 WARNING: CreateDirectory, cant create dir <special://masterprofile/Thumbnails/Video>. trying lower case.
There is more error code, but I hit the text limit for the forum.
blahbleorg Wrote:Hi,
sounds like permission problems. try
chown -R frontrow:frontrow /Users/frontrow/Library/
and see if that fixes it.
blahbleorg Wrote:[snip log]
use a pastebin site like pastebin.com, pastebin.ubuntu.com, rafb.net and post the link here.
HTH,
mdd
I fixed it. I needed to reinstall from the patchstick, then reinstall XBMC. Not sure what went wrong the first time, but there aren't any of the missing file or permissions errors in the log anymore.
Thanks for the help!
