2009-06-05, 05:47
In XBMC I no longer have 1080p as an option for Resolution, which I had before I was screwing around with stuff. I've messed around with everything so much that I've lost track of when this happened.
I started out with a problem of GDM starting in 1024x768, then I'd manually set 1920x1080@60 in nvidia-settings, and from there it was fine. Within XBMC, 1080p was an option and worked great.
So I did some research and found that gnome-display-properties was setting my resolution to 1024x768, went in and changed it to 1920x1080@60, hit apply, and it reverts to 1920x1080@50. 60hz is an option, but it reverts to 50hz when I apply the settings.
Before I had found out that gnome-display-properties was overriding my settings on startup, I had done A LOT of things to try and remedy the problem to the point that I've lost track of a lot of what I've done.
To make a long story short, at one time I was able to have my resolution set to 1920x1080@60, and have my resolution within XBMC set to 1080p. Now the highest it will go is 1920x1080@50 within X (This is even with manually setting it within nvidia-settings), and 1080i 16:9 in XBMC. It also resets my calibration settings for overscan, which I assume is normal if the resolution changes.
What it comes down to is I want X to start in 1920x1080@60 and XBMC to start up in 1080p. Thanks for any help in advance.
Ubuntu 9.04 Jaunty
XBMC 9.04.1 r20654
NVIDIA 8400 GS DVI->HDMI cable to a Sharp LC-C4655U
xorg.conf: http://pastebin.com/m520cf1ff
Xorg.0.log: http://pastebin.com/m37f241b7
xbmc.log: http://pastebin.com/m2b09f420
xrandr output: http://pastebin.com/mbd1ee65
Ubuntu 9.04 Jaunty
XBMC 9.04.1 r20654
