new relax is here.. making it v0.79
relax now works with xbmc!... if you don't use xmbc then don't download this release...
just put in xbmc the path like "xns://yourip:1400/" for the root and "xns://yourip:1400/divx" for your divxes.. etc
forgot to mention all items that are disabled in it
none of us tech-supporters have tested this. if it works - great, but i stand with my old policy that smb is what is recommended for everyone that doesnt have a very special xns need.
i test it for a while so i post this message... and it work!
i use samba for a long and it's only i recomend for normal use.
before i used xns for stream dvb but when it's disable (broken) i used http/rtp.
only post it for this people that like xns...
Quote:relax now works with xbmc!..... if you don't use xmbc then don't download this release
here is the changelog!
v 0.79 (15-aug-2004)
* relax now works with xbmc.. to do that i had to rework the internal file system. that's why the following doesn't work anymore.
- disabled iso support
- disabled xiso support
- disabled zip support
- disabled shoutcast support
- disabled intergrating directorys
- disabled directory flattening
+ filesize reporting
+ filedate reporting
* fixed the filelister reporting incorrect filesizes!
* xbmc scan's for thumbs for each directory.. thats why it's a bit slow when entering a directory with loads of directory's.
* when u disable logging... directory changing in xbmc will become faster.
- some other stuff might now be broken. just mail me and i'll see what i can do.
