Full Version: RegEx Help
I have looked at the stickied post and am at a complete loss as to what to enter to get my tv episodes to show up. They are all set up in one of two ways:
/That_70s_Show/Season 1/That_70s_Show_S01E01.avi
or
/That_70s_Show/Season_1/That_70s_Show_S01E01.avi
anyhelp is greatly appreciated
You don't need to do anything for that layout.
when I autoscan to build my library I get no files under any of my shows. I have tried scanning each folder individually with the same result.
EDIT:
Think I may have figured it out I was using the imdb tv database instead of the thetvdb everything seems to be loading up now.
In that case you've failed to set content on the correct folder. Read the online manual, check a debug log while scanning etc.
We can't help you if you do not provide the necessary information to do so Smile
Cheers,
Jonathan
I got it worked out I was using the wrong database
