Full Version: Adding custom sounds to Aeon?
Have seen a couple of questions about this, so people may not know that you can add sounds to Aeon by simply copying the "sounds" folder (found in the root skin folder of any xbmc skin including, e.g., pm3.hd) from another skin into your Aeon directory.
If you want to customize further, you can also replace any of the mp3 files with ones that you like (so long as you rename them to match the names of the files from pm3.hd).
