Can i use this view on my plugins? I can't find proper id.
something like this code:
if (xbmc.getSkinDir() == "PM3.HD"):
xbmc.executebuiltin('Container.SetViewMode(59)')
else:
pass
You shouldn't really be doing it via SetViewMode. Instead, you should simply be setting the content type and relying on the skin to offer the appropriate view types for the user to select from.
I didn't know that. Thanks for info. You are right, this is what i need
xbmcplugin.setContent(int(sys.argv[1]), 'episodes')
One more question. Can i activate Library mode inside plugin code?
